1 - 7 of 7 Posts
kinda simple but how would I go about securing soft tubing in place to the case? other than obvious
I found these > http://www.performance-pcs.com/adju...ring-with-adhesive-bottom-xx-large-black.html
I want to run it along back of case ( not the back of the case ), it will be visible from TG side panel of my surpressor f31 ( 1st image is of said clamp )
(2nd image) exits cpu to flow meter ( partialy see it here ) then back to pump.. where it exits flow meter to where it enters pump is (2x) 2-90deg rotatable fittings on each end
the zip tie is their to illustrate what I wanna try to do...
I think it will look terrible putting that on your tube like that.
Those sticky pads seem to come off in my experience.
On the back of my motherboard I use similar things for cable ties to attach wires, but I take off the sticky thing and glue it in place first, so that its rock solid.
Do you need to attach it, can you find a better solution, I can't say without seeing the whole tubing layout.
But I would only be tempted to do what you're doing if the tube was totally out of sight.
Eh, Wha?
If you really need to do something like that, I would suggest going oldschool and using a normal metal pipe clamp, painted black, and screwed into the chassis. Something like this:
Newsfiend
Personally I'd stick something to the back of that top fitting to attach it to the case.
1 - 7 of 7 Posts
