1 - 2 of 2 Posts
Hello
Is it genrally okay for for the tubing of this GPU going into the radiator to be bent in this manner? I'm afraid I'm adding some uneeded strain on the fittings.
I couldn't really find a minimum bending radius in the user manual or online for this kind of tube.
Hello
Is that a 120mm rad on the gpu? Could you rotate it?
Those bends look pretty tight but as long as there's no kinks to restrict water flow you should be good.
Sent from my iPhone using Tapatalk
1 - 2 of 2 Posts
