Hello Everyone!
So i'm getting closer to watercooling my sig rig. I now need, tubing, radiators and fittings. I'm having trouble picking what size I will need and look good in my rig, I don't want something too thick or too thin.
In my loop I have a Supremacy Evo, Mosfet Block, RAM block, 2x GPU blocks, EK XE240 x2, and a DDC 3.2 PWM pump w/ 140mm res. Everything will be pretty straight shot, no real tight bends.
I want to use soft tubing at the time as this is my first W/C loop that isn't an AIO unit. I will switch to hard tubing in the future as I see fit
I see a lot of people using 10/16 and 12/16, is there much of a difference between these? What do you personally run? What about the cooling difference, if there is one? Will my pump be an issue with a more restrictive tubing setup (if thats a thing still)? Any tips, tricks or help provided will be much appreciated!!
Thanks,
Pat!
Thanks,
Pat!
