As everybody else said. The TRUE is better out of the two.
I consider the TRUE to still be the best air cooler. The xigmateks are only good with stock CPU's, once the temps rise, frequency is raised and wattage's are increased. (since that's what OCN has been raving about lately)
The TRUE is better but it is rather expensive. I think that if you are going for a mild overclock on your quad, a Tuniq Tower will suffice and save you money.
i agree. the true might be a little better but the tuniqs cheaper and works wonders. go for the tuniq
My 9550 is at 25-23-32-32 (last two seem to be stuck until temps rise above 32) while set at 3GHz. Not much of an OC but it's still pretty chilly under there.
Tuniq is old news in the cooler market, the true and even the Xigmatek S1283 will outperform it. you can grab the xig for $14.99 at microcenter right now which is crazy as can be.
the IFX-14 with 3 fans is better than the TRUE.. but it's also $90 bucks. and the true with 2 fans beats it.
the Tuniq is what I have.. it's decent. It kept ,my Q6700 at 3.5 Ghz around 39c idle and 62c load. and keeps my Q9650 currently around 4.0 Ghz under 37c and 57c load. I actually have a TRUE on the way. Be here in a few days. I'll let ya know. but I'm more than sure it's better.
the Xigmatek s-1283 is in the top 3 with TRUE, OCZ Vendetta and the Xig.. but once you get a mid, to high overclock and new fans. the TRUE pulls ahead of all of them.. get the TRUE!
Overclock.net
