1 - 1 of 1 Posts
Tuniq Tower 120 Extreme 120mm Magnetic Fluid Dynamic CPU Cooler
Description:
The performance king has returned! The much praised Tuniq Tower 120 has gone through a radical redesign and not only looks cooler but its performance has been boosted. The unique wave-like fins display a tremendous visual impact and increase the air-contact area for an unprecedented thermal performance. The nickel-plated surface combined with the LED fan creates a breath taking visual effect! The Tower 120 is the world’s first high-rise CPU cooler. You can tune the speed of the fan with the available controller. The 5 copper heatpipes embedded into the copper base easily transfer the damaging heat from CPU to the huge heatsink. With the airflow created by the ultra-silent magnetic fluid dynamic bearing fan, the heat is quickly eliminated. For maximized contact between copper base and CPU, the high performance thermal grease is included. The cooler is easy to install and perfectly compatible with Intel LGA1156/1366/775 and AMD AM3/AM2+/AM2/K8 (754/939/940) CPUs. The Tuniq Tower 120 Extreme Universal CPU Cooler offers you an extraordinary solution for heat dissipation. Type: Fan & Heatsinks RPM: 1000~2000 RPM LED: Blue Air Flow: 90.65 CFM (Max) Noise Level: 16~20 +/- 10%dBA Compatibility: Intel LGA 1366 / LGA 1156 / LGA 1155 / LGA 775 AMD Socket 754 / 939 / 940 / AM2 / AM2+ / AM3 Heatsink Dimensions: 131(L) Ã- 112.31(W) Ã- 150.7(H) mm Weight: 775g (without fan)
Details:
DetailValue
ManufacturerTUNIQ
ConditionNew
Model NumberCR-T120-EX-BK-RV1
ClassificationCPU Cooling
1 - 1 of 1 Posts
