If the Tuniq is as amazing as they say it is, then I think that 30C idle is a little teensy bit higher than it should be.
The e6400 rig that I just built is 28-30C idle with a BT+FM121 fan.
So unless those two HSFs are head to head equal, then the Tuniq should give a lower temperature.
