1 - 16 of 16 Posts
Hi, I was wondering how much of an improvement would I see using the Tuniq Tower over my current zalman 9500. I have been disappointed with the results I have been getting with the 9500 and I was wondering If I should go ahead and get the Tuniq since it is back in stock.
atm my temps are around 40 idle and can get up to about 58 under load.
Thanks
Blackeagle
Originally Posted by JacKz5o
The TT is a great cooler, get one while you can
TT>BT>9500
ok thanks for the advice, Ill probably go with that.
Discussion Starter #6
Originally Posted by rabidgnome229
The T120 (lapped) can beat out many WC setups. It's well worth the money
what would be the best way to lap it, I looked at the pictures and was like eww that thing could probably cut my hand off. What is the best way to go about lapping?
get a premium lapping kit and easypckits and with some time and patience you will get a mirror finish!
What kind of WC setups can you outperform? Would there be a chance of it doing better than say a Swiftech Apex Ultra? or the less expensive Premium version?
I'm gonna lap mine tomorrow, seems like everyone is lapping right now!
got mine sitting on my lap... right now, was just going to leave it as normal, but after lapping up this whole thread I think i'm going to follow the advice and... eh... whats it called... oh yes, i'm going to sand it
shoot me
What do these lapping kits look like anyway? How are they any different to going out and buying a few sheets of high grit sand paper?
Originally Posted by ****erfx
I'm lapping mine right now =D
Just spent an hour on it and it's still convex.
Mine was convex pretty bad too... I went through about 6 sheets of 600 grit and 1 sheet of 1500 grit. The very outside edges are still not sanded, but the whole 90% middle area is flat (all that matters).
Oh and for a comparison, my TT beats my old watercooling which was:
Dual heatercore, 2x 100CFM 120mm
DD TDX
1/2 clearflex
5.25 clear res
hydor L35
1 - 16 of 16 Posts
