Originally Posted by The Pook
Steam doesn't work with Windows 2003, or I'd be on it now. I love that OS. Shame steam doesn't work though.
I know I am a bit late on this, but it most certainly does. Been running it fine for years and I actually get a little better framerates in 2003 than XP too, not that I need it...
Sometimes you need to find a workaround to get stuff to intstall on 2003 server, but it always works perfectly fine once you get it installed.
The ONLY thing that works in XP that does not work in 2003 is... well nothing, but I can't get SLI in 2003 to work due to an OS check Nvidia put in their drivers after 91.47, however before that when I ran older cards, it worked perfectly too.
However, if you use TweakNT to convert your copy of 2003 to a XP workstation, SLI will work, and you can bypass the OS checks while still running the newer, faster and more stable 2003 kernel (might have to get an activation crack for this to work). Some of the server features may not work, but I assume you want to use this as a workstation anyway. Crossfire users can do the same thing.
Basically if you do the following, any game or application that runs in XP will run just as good or better in 2003.
If you have an ATI video card, ATI included a "dummied down" version of the driver. Use Omega Drivers and they work fine, plus Omega Drivers are more stable, faster and have sharper image quality, can't go wrong there.
After installing your video driver, you need to right click your desktop, go to the settings tab then advanced, go to hardware and slide the slider bar for hardware acceleration all the way up. Hit okay.
Now go start > run and type "dxdiag" and hit ok. Go to the display tab and enable all of your DirectX features.
Stream and all games supported under Steam will work in their entirety if you've done this right. If not then your video card does not support 3D or is too old to
