Turning SB AUdigy into X-Fi Extreme !!
500 Views 1 Reply 2 Participants Last post by  Cerberus
Some of you will probably remember that I placed a topic here about your opinion if I upgraded from my SB Audigy SE to a SB Titanium PCIe.
Well I didn't do it but I downloaded some modded SB XiFi Extreme drivers that work with the SB Audigy SE.
And man, this is AWESOME! The drivers installed flawless in my Windows XP 32bit sp3 and now it says in my hardware section that my card is a SounBlaster X-Fi Extreme Audio.
But the best part is that I can now use the X-Fi Crystalizer and some other things like X-Fi CMSS-3D.
The soundquality just became so much better! I have the Crystalizer switched on and is at 65% (default) and it really makes 128bit MP3 files sound like 256bit MP3.
It's hard to explain in this post how much better the sound is but if someone here has an Audigy SE (and I believe it also works for Audigy 2 and SB Live! cards), they should really try these drivers out!
You can find these drivers here: http://rapidshare.com/files/15160338...79_XP.rar.html
And on this forum is some explaining and also links for Vista drivers: http://forums.techpowerup.com/showth...t=47961&page=3
Best regards, Kodiak.
1 - 2 of 2 Posts
1 - 2 of 2 Posts
