1 - 12 of 12 Posts
I m worried about my cpu temps. It was jus at 55c after exiting from halo. i need to know how to turn up my fan speed, 2 of the fans are below 1000rpm. I dont even hav this thing overcloked. its an hp so i dont kno if there is even the option to turn up the fans. i checked in the bios and all it has there is my fan speed and the temp and no option to change anything.
speedfan says my fan rpm is 122875rpm. thats alot of rpm. is that right cause i m not sure. it has the cpu and motherboard temps rite, their in sync with MBM. but i dont know about the fans.
Originally Posted by pooooop
lol. guess i ll hav to start blowing on my computer while i play games. Thanks for the help.
hehe
I would say buy some new fans with a higher cfm rating and higher rpm. Also get a fan controller then you can manually do it when u need 2
damit. stupid hp.
took the words right outta my mouth
HP= Horrible Puter
Discussion Starter · #11 ·
Speedfan is working great now. has the rite temps and the rite speed rpms. i can increase and decrease rpm and everything. i can keep my computer at about 40-45c while in a game so its alrite now. thnx 4 the help ppl.
glad it worked out for, it doesn't work for me :swearing:
1 - 12 of 12 Posts
