1 - 2 of 2 Posts
Alright, I've decided to give another go at setting up my sound card for using the front audio on my Centurion. I've looked around, and I can't find anything that documents what the various jumpers on the board do. The board itself has a big jumper connector on it, but its pins don't match up to my front audio connector. Does anyone with this card have front audio working with it? I would love to be able to use the ports on my case. It looks like the card uses a c-media chip, so I'll see what I can dig up about it. Apparently it's even older than the chip on my motherboard (!), which is kind of weird since it works with Myst V and my onboard doesn't. Thanks in advance.
It doesn't seem to support front audio... Next time specifically look for front audio to be mentioned in the card's spec. sheet.
1 - 2 of 2 Posts
