1 - 3 of 3 Posts
Or, anything that has this type of insulating foam over the circuit board.
So, i got a 3 channel RheoSmart for playing around with to see if it will 'fit' into my upcoming mod, but i couldnt have that horrid grey foam lurking about, and simply covering it with acrylic wasnt going to work because its amazingly resilient and would bend the acrylic trying to smoosh it down.
Items needed:
fan controller
screw driver
rubbing alcohol (i have 91% on hand, but the regular 70% should work)
cotton swabs
patience, it may take up to an hour
The patient:
Pour enough alcohol onto the foam to fairly soak it, use your finger to spread it around, making sure it reaches the edges
I had the older 4 channel one that needed the same treatment for my wifes pc, so i started on it while the 3 channel soaked
Make sure you dont let the alcohol sit too long, itll start to evaporate, after about 5 minutes you should be able to just peel the foam off
It should look like this
Use additional alcohol and the swabs to clean the remaining glue residue (this stuff is pretty nasty, sticky and dries fast if not soaked) and youll end up with this
Enjoy!!
1 - 3 of 3 Posts
