1 - 20 of 31 Posts
Hello everyone,
I thought I'd make this guide because I couldn't really find another for this specific memory. But before we go any further, I'd like to say
WARNING: THIS WILL VOID YOUR WARRANTY! DO THIS AT YOUR OWN RISK!
450
If anyone was wondering, this is the specific model I will be using: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231497.
I am not sure if this method works on Ripjaws X (confirmed), Ares, or Trident (confirmed); if someone can confirm or deny if this works that'd be very helpful.
So anyways, let's get started!
This is what you'll need:
  • The memory module itself
    450
  • Something to pry the heatspreader with (I will be using a nail file on a pocket knife. A flat head screwdriver also works.
    450
  • Aftermarket heatspreader*
    450
  • Heat gun*
    625
* These are optional. For an alternative to the heat gun, you could use a blow dryer or run Prime95 for a few minutes beforehand
The Process Itself:
  1. If you are using a heat gun or miscellaneous heating method, do this now.
  2. Take your prying tool and pry downward on the side of the heatspreader so that it lifts up.
    450
  3. Do this again, except on the other side.
    450
  4. Now pry in middle near the notch. Do this again in both directions.
    450
  5. Now take your hands and slowly pry that one side off. The thermal adhesive is fairly weak, so if you did this right, all of your memory chips should be in tact.
    450
    450
  6. On the top, there are two interlocking clips. Take the side you pulled off and slide it through.
    450
  7. Here is the one side completed.
    450
  8. Repeat these steps on the other side. This is what your module should look like when you are done:
    450
  9. Congradulations! You may or may not be done. Keep reading if you'd like to see how to install an aftermarker heatspreader.
  10. Take the clips off of your heatspreader and place the module in between it. Be sure to remove any protective covers on the adhesive strip inside, if they are present. Mine did not come with any, so that was not an issue.
    450
  11. Put the clips back on.
    450
  12. Yay we're finally done!
    450
    450
Here's a picture of all of the modules installed:
400
I hope this helped! Let me know if you have any questions, or if I need to edit anything
Nice guide! I actually was going backwards from what you did here, I had the heatsinks you put on last on some of my first ram, but I didnt like the colors I used. They were not ripjaws. I then purchased a cheap set of ripjaws off the egg and really liked the color scheme, so I bought someones set of spare sinks off OCN to match my existing ram and now have all matching modules.
+r
+r
Thanks! That sounds like an interesting idea. Did it work out ok?
I can confirm that this method of removing the heat spreader works for the Trident X. (I haven't tried the stick in a machine yet, but the memory chips were cool enough to not burn me upon touching them immediately after pulling the spreaders off.)
Discussion Starter · #6 ·
Awesome thanks for the confirmation! Included it as an edit in the original post
Discussion Starter · #8 ·
Originally Posted by pratesh View Post
I'm considering anodizing my Ripjaw Z from red to black. I don't wanna buy new RAM, so I might decide to do this.
If you end up anodizing it, please take pictures! It'd be cool to a build log
Discussion Starter · #11 ·
Originally Posted by Big-Pete View Post
lol necro:rolleyes: will be doing this with my ripjaws X, and respray the spreader in Asus blue
Sweet! Good luck with that; I bet it will turn out pretty sick
Originally Posted by tSgt View Post
Hi !
Even if i hate to necro, i've found this guide completely randomly while searching for a way to remove heatspreader of g.skill memory sticks in order to install this :
http://www.ekwb.com/shop/blocks/ram-blocks/ek-ram-dominator-module-black-2pcs.html
+ this
http://www.ekwb.com/shop/blocks/ram-blocks/ek-ram-dominator-x2-acetal-nickel.html
Big Thanks to you YouGotJaked !
No problem glad you found my guide!
Thanks for making this guide... I was wondering how hard it would be to remove the heat shinks off the ram and now I know..
Discussion Starter · #13 ·
No problem that's why I made it
I have some Ripjaws X I want to remove the heatsinks off to paint. I have a few questions, will I need some heat-resistant paint for the heatsinks? And are the thermal pads on the chips reusable, if not, where could I get some?
Discussion Starter · #16 ·
I'd recommend using heat-resistant paint, but honestly RAM doesn't even get hot to the touch so it shouldn't be that much of an issue. And yes you can reuse the thermal pads if you want
Reactions: Hemi177
Thanks for the info! +1 I'll post some pictures of how they turn out when done, painting them black
Discussion Starter · #18 ·
Awesome can't wait to see how they turn out!
There are candy color paints that are transparent and look very much like anodization.
I've used single-edged razor and pry between the heatsink and chip, never between the heatsink and circuit board. A heat gun set to low temperature or a hair dryer is still a must.
1 - 20 of 31 Posts
