I was trying to figure out the easiest 1000watt+ psu for sleeving, and was going to go with the Corsair AX 1200i, but I couldn't get over the price difference between the AX1200 and the EVGA G2. Needless to say I ended up going with the G2. I was originally turned off to the G2 due to dealing with capacitors on the cables. I didn't want to remove them as others have done, nor did I want to deal with the added complexity of sleeving with them, but decided to do so due to the price difference between the psu's.
I haven't seen any sleeving where the capacitors were kept in place, so I thought I'd share my results.
This is my first time sleeving or lacing, I think the cable came out fairly decent.
I want to give a big thanks to Lutro0 for his videos, tutorials, and FAQ's on sleeving. I never would have attempted this without his contribution. His work is great. Thanks Lutro0!!
I created my own pin-out diagram that denotes double wires, capacitors (get the polarity right!), and importantly, wire gauges. if you aren't replacing the wires with all 16awg, but rather, using the existing wires, make sure you keep the wire gauges straight. The G2 I have uses 16awg, 18awg, 22awg, and 20awg wires. Don't want to accidentally use the 20awg wire where a 16awg wire should be used.
The pin to pin mapping for the G2 I have is different than that posted in the Repository Of Power Supply Pin Outs. I posted my updated pin-out for "new" G2's, it is repeated below in case you need it and don't want to dig through the repository thread as the G2 hasn't been updated with my pin-out yet.
Off to the sleeving!
The Power Supply:
The 24pin ATX cable with sleeving removed:
3x 220uF Capacitors (messy!):
I never realized that the pin numbers were labeled on the back of ATX connectors, need to get the light correct to see them:
My sleeve, red, white, and black paracord:
Step 1: Is to remove the heat shrink holding the capacitors, be careful, they used adhesive heat shrink and it is a royal pain to remove. I used my x-acto knife, I know it's common sense, but worth repeating, cut away from yourself. It is much to easy to slip when removing this heat shrink.
Step 2: Measure out the sleeve and get it on the wires, Lutro0's paracord threading tool is invaluable here (ok..not invaluable as it is priced at $12.50, but worth every cent!). After I had the sleeve threaded on the wire, I shrunk the ends with a lighter (I'm going heat shrink-less).
Step 3: Super glue the ends of the sleeve where they meet at the capacitor
Step 4: Measure out the heat shrink and thread it over the sleeving, then hit it with the heat gun
The result is pretty decent, you could stop here and be done, however I wanted to reinforce the cable such that it couldn't be pulled apart and damage the capacitor connection, so I used heat shrink to hold the wires together above and below the capacitor.
Now go ahead and plug it into the connectors! One thing to note, from the factory, EVGA places the capacitors near the motherboard end of the 24pin connector, when I reconnected the wire I put the capacitors on the PSU side of the cable so as to have a cleaner look. This isn't an issue as long as you plug the wires in such that the polarity of the capacitors are maintained.
Here is the 24pin connector before plugging in the PSU side plugs:
A close-up of the capacitors and double wires (I messed up the black double wire..ugh)
I wanted to try cable lacing and followed Frank's lacing method (https://www.youtube.com/watch?v=La6LbgnZJco). However I used a thin "invisible" thread to try and get a "stealth" look (http://www.amazon.com/gp/product/B0053A4FUI/ref=oh_details_o06_s00_i00?ie=UTF8&psc=1). At the beginning when I first tired, I ended up snapping the thread when I pulled a knot tight. I went ahead and doubled up on the thread which seemed to solve the problem.
I used 1.5" spacing for the thread. I like the way it looks, but it is taking me an embarrassingly long amount of time to do this. The wire is so darn thin, and being transparent, I have issues seeing things and threading correctly! Frustrating to say the least. While I really like the way it looks, I'm almost tempted to throw in the towel, cut them off, and get cable combs....
Well, that's all I have. Let me know what you think!
The Power Supply:
