Originally Posted by nate911
About ReadyBoost, I have read somewhere it makes almost no difference. I have a 2GB Flashdrive, should I use it and would it make a difference?
Assuming that it is "ready boost ready", you can store 4GB of compressed "super fetch" data on it. The difference on your rig will not be noticeably affected right away, but will be noticeable over time. See, the "superfetch" data is a artifically intelligent tracker of your habits. Over time, your PC learns what programs you run morning v evening, before lunch/after lunch, weekdays/weekends, etc. So, if you always check your email first, then the data for your email is stored on the superfetch "page file" and is retrieved faster from the flash drive than from your HD.... it is worth it, if you aren't using it for something else. Personally, I use a high-speed 4gb CF card, so that I don't have the obtrusion of yet another thumbdrive sticking out of yet another usb hub. Also, changing the polling of your USB 2.0 device to match that proposed in the new USB 3.0 standard will help as well, but is so complicated to do that even I have yet to try it... will post directions after I try it on one of my P.O.S. compaq's.
