[TWEAKTOWN] Xigmatek Thor’s Hammer S126384 H.D.T. CPU Cooler
987 Views 13 Replies 10 Participants Last post by  TestECull
Check out the new Xigmatek Thor's Hammer S126384 H.D.T. CPU Cooler
Source
Sorry if Repost
1 - 14 of 14 Posts
Published: 18th February 2009
A bit old, don't you think?
Yeah is it a repost or not
It's a bit old, but I hadn't seen this review.
Odd results just like in most reviews, and they don't even test it on a real CPU. I'm wondering why they said it's a top air cooler, yet got beat by a lot of them in the review.
It looks effective.
I also want to know how their load temps are only 5C higher than idle. That doesn't seem like much of a heat load to me.
lol i thought this was gonna be thor's hammer REV 2 or something...
It is a different way of testing CPU coolers.
I know it's different but "idle" to me is really low wattage, and "load" is quite a bit more wattage. Only a small difference like that doesn't make sense to me even if they're not using an actual CPU to do the testing.
Why oh why was the chart not at all ordered in anyway according to performance?
Their reviews are terrible imo.
Xiggy, no bolt-thru lovin' for AMD? You suck. You should know better than trust that thin plastic bracket to hold 800 grams of cooler on there...
1 - 14 of 14 Posts
