1 - 20 of 55 Posts
Twin Frozr 4 vs DirectCu II
First of all I would like to inform you that this is not a comparison of the MSI GTX 680 Lightning and the ASUS GTX 680 DCII TOP cards. It is a comparison of their cooling solutions which has caused some debate on this forum. I got pretty tired of people going back and forth over which cooled better or which was quieter or which one had the fastest fan speeds. So since I have both cards I decided to compare both of them in my system and share with everyone the results. So first things first.....PICTURE TIME!!!
Twin Frozr 4
DirectCu II
So as far as appearance goes, you can judge for yourself. This isn't a beauty contest. This comparison is strictly on performance. So on to the test bench specs.
Hardware
Processor: Intel i7 3930K @ 4.8GHz
Mobo: ASUS Rampage IV Formula
Memory: G.Skill RipjawZ 16GB @ 2133MHz
Storage: 2x Crucial M4 128GB SSD RAID 0
Software
Windows 7 Professional
Afterburner v2.2.3
HWMoniter v1.90
Testing Equipment
ACU-RITE Temperature Monitor
Digital Instruments SL-814 Digital Sound Level Meter
TESTING
During the tests the Lightning was using the stock BIOS and both cards were OCed to a mild 1250MHz on the core.These two cards were designed to OC, so it didn't make any since to test the cooling at reference settings. During the temperature tests I ran Heaven at max settings @ 1920x1080 for ten minutes. At first I ran it longer but noticed that the temps would level off around ten minutes.
Average home 50dB
http://www.sengpielaudio.com/TableOfSoundPressureLevels.htm
I was a little surprised by the outcome. I knew the stats would be close but I thought for sure that the DCII would have the best temps. Overall if I had to chose between the two it would have to be the Twin Frozr even though I like the way the DCII looks (it matches my theme). The DCII is just too big (triple slot) for the performance that you get out of it. I blame it on their fan design. The angle of the fan blades are more aggressive as compared to the TF4. The design could easily be a two slot if they redesign the fans.
This is my first review so if it looks like I left something out, let me know.
- Jared
PC Evangelist
Just looking at the design you can see that a lot more work went to the TF4. Asus was always lazy with DCII making it a Triple Slot.
Not a Fan
Regardless of the outcome, thanks for pulling them apart so we can see what's in there.
And if it's any consolation, I own the Lightning and think "Twin Frozr" is possibly one of the lamest names in computer hardware. I'm glad the cards have the shrouds on the bottom so nobody can see that printed on the things.
POWER LURKER
Thanks for this review. Really helps, I guess I'm sticking with a Twin Frozr cooler for round 3
+rep for contributing!
great comparison, thanks for the stats and high quality images
Good job, love my tf4 and the tf3 before it, always great coolers
Nice comparison. Think you'd be interested in doing one with the DCII V2 (cooler that's on the gtx670 DCII/HD7870DCII V2 cards) cooler and maybe the gigabyte windforce X3?
Discussion Starter #14
Are you going to send me these two cards?
I don't know if I would compare the DCII V2 since it is on a 670 and 7870. I decided to compare the TF4 and DCII because I had them both on 680s. This leaves little to debate on which one performs better. If I would have done the review with one 680 and one 7970 the comparison would have been flawed. I would like to try and compare other cooling solutions for the 680 (Windforce, Signature 2, Amp!) but that takes money.
Well I already sent the DC2T back to asus for rma. It's going to another member as soon as I get it back and test it so I won't be able to do that
. Since the 670 has both designs I might be interested in a comparison some day.
I'm a little curious as to how you measured the sound levels
I'm not really sure what the standard distance is for people who measure sound levels
But 50-60 db sounds awfully high to me, although I don't have any first hand experience with either of those two air coolers
Though I do know that air coolers do tend to be quite loud.
1 - 20 of 55 Posts
