1 - 11 of 11 Posts
Hi
Well it seems like my memory is makin my comp instabil whit prime
Running the memory att 400 mzh whit timing 6.2.2.2,5 now and it crashes in prime
if i turn down to 133mhz its fine.
Running 2.77 volt on mems
uhm tried running 7.2.2.2,5 and 400mhz crash after 5 min lol
god okej runnin 7.3.3.2,5 now att 2.77 volt and no crash for 10 min LOL im on test nr 2 now
Multi is 133x11.5 erm 1730 mhz
Uhm changed to 166x10.5 =1740 mhz Vcore default 1.65 400mhz mem 7.2.2.2,5 timings.No crash for 10 min. Im da nOOb =D when i raise FSB and keep same clock speed on FSB do i need to raise vcore? =P
Originally Posted by Sper
Hi
god okej runnin 7.3.3.2,5 now att 2.77 volt and no crash for 10 min LOL im on test nr 2 nowif its crashing
a little wont hurt but it sounds like its gettin hot to me and shutting doown.be carefull dude.
uhm okej i ran prime 95 torture for 2hours whit these settings whitout error
9x200 =1800mhz
Memory timings 7.3.3.2,5 400mhz
Full load on cpu was 47cel
It seems like it was the memory timings that made my comp instabil.
Gonna run Prime over night for 12 hours atleast
Are you watching your temps??? You have some good speeds but what temps are you seeing in the System and CPU? Do you have good case (system) temps = good air flow in and out?
I ran Prime 95 torture test tonight for 10 hours 0 Error and 0 Warnings
Max Cpu temp 46 celsius
Max Case 34C
Motherboard 27c
Hey,
I also have 2 x 256MB Twinmos DDR400/PC3200.....My computer crashes when I run them at 200MHz...my system is stable when I run at 166MHz...
I dont know what the problem is but it sucks.....next time I'll take Kingston...
id invest in a zalman CNPS7000 for your CPU and some arctic silver ceramique to keep your CPU temps right down, id also up the vdimm on your memory to 3v and then go from there. updating your mobos bios will help too.
Hey Ket,
was that information for me....???
Looks like you'r going to have to try a CAS3 config if you want to get higher FSB speeds!
1 - 11 of 11 Posts
