two 260's or one 295?
385 Views 11 Replies 12 Participants Last post by  linskingdom
what would be better 2-260gtx or 1 295gtx? this is going on my main rig so im thinking 2-260's so i can game and still fold on the other card but i would like some opinions before i buy anything.
1 - 12 of 12 Posts
1 295 would be a bit more future proof, as you could get another later, but really its up to you and what you can afford.
One 295, and just game less so you can fold more :-D
2 x 260's would a lot cheaper, you could almost get 3 for the price of 1 295.
Tough one regarding [email protected], roughly the same output with the 295 slightly a head with the heavier units.
I'd get the 295, i prefer a 1 slot card, also in the future you could get a second 295
for gaming my vote will go to the SLI GTX260's, bunch since you suggested a gtx295 i would say why not sli GTX285's?
I would go with the one 295GTX, then later I would get another one when your budget allows.
295,you can add 1 more later.
If you can wait 6-7 months,DX11 cards are to be out when Win7 is (6-7 months) so i'd wait for 'em.
But all DX10 cards work with DX11
dependent on board and money. with your config, 2-216 - much cheaper.
A few months ago I would've said 1 295 as they were cheaper than 2-216.
I guess if the plan is to Fold and game at the same time? Then the SLI would have to be the best option. I don't know if the 295 is capable of doing that just the same or not personally. I have not done my homework on Micro Stutter with current drivers and Graphics cards and is the only reason why I frown upon SLI.
GXT260 SLI is cheaper then GXT295. Go for GXT295 if you has budget on it. Otherwise, do GTX260 SLI.
1 - 12 of 12 Posts
