Originally Posted by ljason8eg
Easiest way to do that is plug the sub into the sub/center channel of the sound card/onboard audio.
Actually, now that I can see the back of the speakers....it MIGHT also work fine if you went from the speaker output (for the right speaker) to the sub's high level inputs. You'll only get the right channel this way, but the volume control on the speakers would control the speakers and sub.
If you did go from the sound card to the sub, you'll have to use Windows to control the volume. Just keep that in mind.
Or if you don't care about warranty, it wouldn't be too terribly difficult to tear that left speaker apart, and mod an actual RCA output that would work as well. You'd just wire a Hi Level Converter inside the enclosure, and drill holes in the rear for the RCA outputs....glue them in
. Or instead of using a HLC, you could also just wire in a set of speaker outputs on the rear of the Left....using the Left AND the right side...and run those to the hi level input of said subwoofer.
