[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.27-7-generic (
[email protected]) (gcc version 4.3.2 (Ubuntu 4.3.2-1ubuntu11) ) #1 SMP Tue Nov 4 19:33:20 UTC 2008 (Ubuntu 2.6.27-7.16-generic)
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001f800000 (usable)
[ 0.000000] BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
[ 0.000000] last_pfn = 0x1f800 max_arch_pfn = 0x100000
[ 0.000000] kernel direct mapping tables up to 1f800000 @ 7000-c000
[ 0.000000] RAMDISK: 1f023000 - 1f7ef847
[ 0.000000] DMI 2.3 present.
[ 0.000000] ACPI Error (tbxfroot-0218): A valid RSDP was not found [20080609]
[ 0.000000] ACPI: BIOS age (1997) fails cutoff (2000), acpi=force is required to enable ACPI
[ 0.000000] ACPI: Disabling ACPI support
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 504MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1f800000
[ 0.000000] low ram: 00000000 - 1f800000
[ 0.000000] bootmap 00002000 - 00005f00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 001f800000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00005c0a20] TEXT DATA BSS ==> [0000100000 - 00005c0a20]
[ 0.000000] #4 [001f023000 - 001f7ef847] RAMDISK ==> [001f023000 - 001f7ef847]
[ 0.000000] #5 [00005c1000 - 00005c4000] INIT_PG_TABLE ==> [00005c1000 - 00005c4000]
[ 0.000000] #6 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000002000 - 0000006000] BOOTMAP ==> [0000002000 - 0000006000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001f800
[ 0.000000] HighMem 0x0001f800 -> 0x0001f800
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001f800
[ 0.000000] On node 0 totalpages: 128927
[ 0.000000] free_area_init_node: node 0, pgdat c048a500, node_mem_map c1000000
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 123830 pages, LIFO batch:31
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] mapped APIC to ffffb000 (01470000)
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 1f800000:e07f0000)
[ 0.000000] PERCPU: Allocating 41628 bytes of per cpu data
[ 0.000000] NR_CPUS: 64, nr_cpu_ids: 1, nr_node_ids 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 127793
[ 0.000000] Kernel command line: root=UUID=9f289411-6e3f-46b5-a95a-1a5bfe159ef4 ro quiet splash
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 2048 (order: 11, 8192 bytes)
[ 0.000000] TSC: Using PIT calibration value
[ 0.000000] Detected 866.645 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.004000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.004000] Memory: 497736k/516096k available (2572k kernel code, 17892k reserved, 1160k data, 424k init, 0k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xffc77000 - 0xfffff000 (3616 kB)
[ 0.004000] pkmap : 0xff400000 - 0xff800000 (4096 kB)
[ 0.004000] vmalloc : 0xe0000000 - 0xff3fe000 ( 499 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xdf800000 ( 504 MB)
[ 0.004000] .init : 0xc04ab000 - 0xc0515000 ( 424 kB)
[ 0.004000] .data : 0xc03832aa - 0xc04a5680 (1160 kB)
[ 0.004000] .text : 0xc0100000 - 0xc03832aa (2572 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.004000] SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.004031] Calibrating delay loop (skipped), value calculated using timer frequency.. 1733.29 BogoMIPS (lpj=3466580)
[ 0.004100] Security Framework initialized
[ 0.004135] SELinux: Disabled at boot.
[ 0.004214] AppArmor: AppArmor initialized
[ 0.004242] Mount-cache hash table entries: 512
[ 0.004817] Initializing cgroup subsys ns
[ 0.004832] Initializing cgroup subsys cpuacct
[ 0.004841] Initializing cgroup subsys memory
[ 0.004890] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 0.004899] CPU: L2 cache: 256K
[ 0.004911] CPU serial number disabled.
[ 0.004965] Checking 'hlt' instruction... OK.
[ 0.020947] SMP alternatives: switching to UP code
[ 0.032084] Freeing SMP alternatives: 11k freed
[ 0.032439] weird, boot CPU (#0) not listedby the BIOS.
[ 0.032450] SMP motherboard not detected.
[ 0.032462] Local APIC not detected. Using dummy APIC emulation.
[ 0.032468] SMP disabled
[ 0.032882] Brought up 1 CPUs
[ 0.032895] Total of 1 processors activated (1733.29 BogoMIPS).
[ 0.032968] CPU0 attaching sched-domain:
[ 0.032981] domain 0: span 0 level CPU
[ 0.032990] groups: 0
[ 0.034288] net_namespace: 840 bytes
[ 0.034328] Booting paravirtualized kernel on bare hardware
[ 0.035025] Time: 7:17:36 Date: 11/18/08
[ 0.035189] NET: Registered protocol family 16
[ 0.037483] EISA bus registered
[ 0.065836] PCI: PCI BIOS revision 2.10 entry at 0xfdb01, last bus=1
[ 0.065852] PCI: Using configuration type 1 for base access
[ 0.069993] ACPI: Interpreter disabled.
[ 0.070013] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.070165] pnp: PnP ACPI: disabled
[ 0.070183] PnPBIOS: Scanning system for PnP BIOS support...
[ 0.070331] PnPBIOS: Found PnP BIOS installation structure at 0xc00f7150
[ 0.070341] PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0x6014, dseg 0xf0000
[ 0.073172] PnPBIOS: 13 nodes reported by PnP BIOS; 13 recorded by driver
[ 0.074862] PCI: Probing PCI hardware
[ 0.074880] PCI: Probing PCI hardware (bus 00)
[ 0.075177] PCI: 0000:00:00.0 reg 10 32bit mmio: [c0000000, cfffffff]
[ 0.075302] PCI: 0000:00:02.0 reg 10 32bit mmio: [dffdf000, dffdffff]
[ 0.075434] PCI: 0000:00:0c.0 reg 10 io port: [d800, d8ff]
[ 0.075479] pci 0000:00:0c.0: supports D1
[ 0.075485] pci 0000:00:0c.0: supports D2
[ 0.075534] PCI: 0000:00:0c.1 reg 10 io port: [dc00, dc3f]
[ 0.075578] pci 0000:00:0c.1: supports D2
[ 0.075585] pci 0000:00:0c.1: PME# supported from D0 D2 D3hot D3cold
[ 0.075595] pci 0000:00:0c.1: PME# disabled
[ 0.075638] PCI: 0000:00:0e.0 reg 10 io port: [d400, d4ff]
[ 0.075649] PCI: 0000:00:0e.0 reg 14 32bit mmio: [dffff000, dfffffff]
[ 0.075677] PCI: 0000:00:0e.0 reg 30 32bit mmio: [dffa0000, dffbffff]
[ 0.075696] pci 0000:00:0e.0: supports D1
[ 0.075701] pci 0000:00:0e.0: supports D2
[ 0.075706] pci 0000:00:0e.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.075715] pci 0000:00:0e.0: PME# disabled
[ 0.075764] PCI: 0000:00:0f.0 reg 20 io port: [ffa0, ffaf]
[ 0.075855] PCI: 0000:01:00.0 reg 10 32bit mmio: [de000000, deffffff]
[ 0.075866] PCI: 0000:01:00.0 reg 14 32bit mmio: [ba000000, bbffffff]
[ 0.075891] PCI: 0000:01:00.0 reg 30 32bit mmio: [dfef0000, dfefffff]
[ 0.075946] PCI: bridge 0000:00:01.0 io port: [b000, bfff]
[ 0.075956] PCI: bridge 0000:00:01.0 32bit mmio: [dde00000, dfefffff]
[ 0.075966] PCI: bridge 0000:00:01.0 32bit mmio pref: [b9c00000, bdcfffff]
[ 0.078014] pci 0000:00:07.0: ALI IRQ router [10b9/1533]
[ 0.078072] pci 0000:00:0f.0: hardcoded PCI INT A -> IRQ 14
[ 0.078565] NET: Registered protocol family 8
[ 0.078565] NET: Registered protocol family 20
[ 0.078565] NetLabel: Initializing
[ 0.078565] NetLabel: domain hash size = 128
[ 0.078565] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.078565] NetLabel: unlabeled traffic allowed by default
[ 0.080286] tracer: 772 pages allocated for 65536 entries of 48 bytes
[ 0.080293] actual entries 65620
[ 0.081251] AppArmor: AppArmor Filesystem Enabled
[ 0.081377] system 00:00: iomem range 0x0-0x9fbff could not be reserved
[ 0.081387] system 00:00: iomem range 0x9fc00-0x9ffff could not be reserved
[ 0.081397] system 00:00: iomem range 0xf0000-0xfffff could not be reserved
[ 0.081405] system 00:00: iomem range 0x100000-0x1f7fffff could not be reserved
[ 0.081416] system 00:00: iomem range 0xffff0000-0xffffffff could not be reserved
[ 0.084519] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.084535] pci 0000:00:01.0: IO window: 0xb000-0xbfff
[ 0.084548] pci 0000:00:01.0: MEM window: 0xdde00000-0xdfefffff
[ 0.084558] pci 0000:00:01.0: PREFETCH window: 0x000000b9c00000-0x000000bdcfffff
[ 0.084590] pci 0000:00:01.0: setting latency timer to 64
[ 0.084601] bus: 00 index 0 io port: [0, ffff]
[ 0.084607] bus: 00 index 1 mmio: [0, ffffffff]
[ 0.084613] bus: 01 index 0 io port: [b000, bfff]
[ 0.084619] bus: 01 index 1 mmio: [dde00000, dfefffff]
[ 0.084626] bus: 01 index 2 mmio: [b9c00000, bdcfffff]
[ 0.084632] bus: 01 index 3 mmio: [0, 0]
[ 0.084690] NET: Registered protocol family 2
[ 0.085301] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.086277] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.087236] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.088317] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.088336] TCP reno registered
[ 0.089064] NET: Registered protocol family 1
[ 0.089658] checking if image is initramfs... it is
[ 2.077836] Freeing initrd memory: 7986k freed
[ 2.080996] audit: initializing netlink socket (disabled)
[ 2.081076] type=2000 audit(1226992658.080:1): initialized
[ 2.097260] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 2.107649] VFS: Disk quotas dquot_6.5.1
[ 2.108115] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.108686] msgmni has been set to 987
[ 2.109301] io scheduler noop registered
[ 2.109311] io scheduler anticipatory registered
[ 2.109318] io scheduler deadline registered
[ 2.109387] io scheduler cfq registered (default)
[ 2.109541] pci 0000:00:07.0: Activating ISA DMA hang workarounds
[ 2.109594] pci 0000:01:00.0: Boot video device
[ 2.110768] isapnp: Scanning for PnP cards...
[ 2.465202] isapnp: No Plug & Play device found
[ 2.687027] Serial: 8250/16550 driver4 ports, IRQ sharing enabled
[ 2.687386] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.691262] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.698690] brd: module loaded
[ 2.699020] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 2.699567] PNP: PS/2 Controller [PNP0303,PNP0f13] at 0x60,0x64 irq 1,12
[ 2.703595] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.703620] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.705668] mice: PS/2 mouse device common for all mice
[ 2.706309] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 2.706371] rtc0: alarms up to one day
[ 2.706846] EISA: Probing bus 0 at eisa.0
[ 2.706913] EISA: Detected 0 cards.
[ 2.706926] cpuidle: using governor ladder
[ 2.706933] cpuidle: using governor menu
[ 2.708889] TCP cubic registered
[ 2.709010] Using IPI No-Shortcut mode
[ 2.710249] registered taskstats version 1
[ 2.710526] Magic number: 0:842:268
[ 2.710687] tty ttyud: hash matches
[ 2.711078] rtc_cmos 00:04: setting system clock to 2008-11-18 07:17:39 UTC (1226992659)
[ 2.711089] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 2.711095] EDD information not available.
[ 2.713867] Freeing unused kernel memory: 424k freed
[ 2.714070] Write protecting the kernel text: 2576k
[ 2.714200] Write protecting the kernel read-only data: 936k
[ 2.749853] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 3.292504] fuse init (API version 7.9)
[ 3.558993] thermal: Unknown symbol acpi_processor_set_thermal_limit
[ 4.607146] usbcore: registered new interface driver usbfs
[ 4.607242] usbcore: registered new interface driver hub
[ 4.644908] usbcore: registered new device driver usb
[ 4.853385] SCSI subsystem initialized
[ 4.853701] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.853834] ------------[ cut here ]------------
[ 4.853841] WARNING: at /build/buildd/linux-2.6.27/arch/x86/pci/irq.c:208 pirq_ali_get+0x55/0x70()
[ 4.853849] Modules linked in: ohci_hcd(+) scsi_mod dock mii usbcore fbcon tileblit font bitblit softcursor fuse
[ 4.853886] Pid: 972, comm: modprobe Not tainted 2.6.27-7-generic #1
[ 4.853897] [<c037c406>] ? printk+0x1d/0x1f
[ 4.853937] [<c0131de9>] warn_on_slowpath+0x59/0x90
[ 4.853971] [<c011ab70>] ? native_restore_fl+0x0/0x10
[ 4.854003] [<c011ab80>] ? native_irq_disable+0x0/0x10
[ 4.854014] [<c011ab90>] ? native_irq_enable+0x0/0x10
[ 4.854025] [<c011aba0>] ? native_safe_halt+0x0/0x10
[ 4.854035] [<c011abb0>] ? native_halt+0x0/0x10
[ 4.854046] [<c0252b01>] ? number+0x291/0x2a0
[ 4.854073] [<c0123215>] ? dequeue_entity+0x15/0x180
[ 4.854084] [<c02e1c22>] ? pci_conf1_read+0xc2/0x100
[ 4.854095] [<c02e3931>] ? raw_pci_read+0x81/0x90
[ 4.854107] [<c02e3a04>] ? pci_read+0x34/0x40
[ 4.854117] [<c025d3e0>] ? pci_bus_read_config_byte+0x60/0x70
[ 4.854145] [<c02e3145>] pirq_ali_get+0x55/0x70
[ 4.854154] [<c02e30f0>] ? pirq_ali_get+0x0/0x70
[ 4.854164] [<c02e3322>] pcibios_lookup_irq+0x192/0x520
[ 4.854174] [<c02e3a04>] ? pci_read+0x34/0x40
[ 4.854185] [<c02e3704>] pirq_enable_irq+0x54/0x200
[ 4.854196] [<c02e3af0>] pcibios_enable_device+0x30/0x40
[ 4.854206] [<c02612ca>] do_pci_enable_device+0x2a/0x60
[ 4.854218] [<c0261366>] __pci_enable_device_flags+0x66/0x80
[ 4.854230] [<c0261392>] pci_enable_device+0x12/0x20
[ 4.854239] [<e009b8c4>] usb_hcd_pci_probe+0x54/0x2c0 [usbcore]
[ 4.854420] [<c020104a>] ? sysfs_do_create_link+0xaa/0x130
[ 4.854438] [<c0262729>] ? pci_match_id+0x9/0xa0
[ 4.854453] [<c0262966>] ? pci_match_device+0xc6/0xd0
[ 4.854464] [<c026315e>] pci_device_probe+0x5e/0x80
[ 4.854476] [<c02c3cb9>] really_probe+0x59/0x190
[ 4.854493] [<c0262966>] ? pci_match_device+0xc6/0xd0
[ 4.854504] [<c02c3e33>] driver_probe_device+0x43/0x60
[ 4.854514] [<c02c3ec9>] __driver_attach+0x79/0x80
[ 4.854523] [<c02c3593>] bus_for_each_dev+0x53/0x80
[ 4.854533] [<c02630a0>] ? pci_device_remove+0x0/0x40
[ 4.854543] [<c02c3b6e>] driver_attach+0x1e/0x20
[ 4.854552] [<c02c3e50>] ? __driver_attach+0x0/0x80
[ 4.854561] [<c02c2f37>] bus_add_driver+0x1b7/0x230
[ 4.854571] [<c02630a0>] ? pci_device_remove+0x0/0x40
[ 4.854581] [<c02c409e>] driver_register+0x6e/0x150
[ 4.854592] [<e0014000>] ? ohci_hcd_mod_init+0x0/0x49 [ohci_hcd]
[ 4.854613] [<c026338f>] __pci_register_driver+0x4f/0x90
[ 4.854623] [<e0014000>] ? ohci_hcd_mod_init+0x0/0x49 [ohci_hcd]
[ 4.854635] [<e0014045>] ohci_hcd_mod_init+0x45/0x49 [ohci_hcd]
[ 4.854647] [<c0101120>] _stext+0x30/0x160
[ 4.854658] [<c012b4ee>] ? try_to_wake_up+0xde/0x290
[ 4.854670] [<c014c604>] ? __blocking_notifier_call_chain+0x14/0x70
[ 4.854699] [<c015c208>] sys_init_module+0x88/0x1b0
[ 4.854732] [<c0104072>] syscall_call+0x7/0xb
[ 4.854747] =======================
[ 4.854754] ---[ end trace 60fb89680124a6e6 ]---
[ 4.854763] PCI: setting IRQ 10 as level-triggered
[ 4.854772] ohci_hcd 0000:00:02.0: found PCI INT A -> IRQ 10
[ 4.854856] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 4.855068] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
[ 4.855132] ohci_hcd 0000:00:02.0: irq 10, io mem 0xdffdf000
[ 4.873030] sis900.c: v1.08.10 Apr. 2 2006
[ 4.948124] usb usb1: configuration #1 chosen from 1 choice
[ 4.948269] hub 1-0:1.0: USB hub found
[ 4.948322] hub 1-0:1.0: 2 ports detected
[ 5.026104] libata version 3.00 loaded.
[ 5.154033] PCI: setting IRQ 3 as level-triggered
[ 5.154051] sis900 0000:00:0e.0: found PCI INT A -> IRQ 3
[ 5.155340] 0000:00:0e.0: SiS 900 Internal MII PHY transceiver found at address 1.
[ 5.164700] 0000:00:0e.0: Using transceiver found at address 1 as default
[ 5.348836] usb 1-1: new full speed USB device using ohci_hcd and address 2
[ 5.573105] usb 1-1: configuration #1 chosen from 1 choice
[ 6.802242] eth0: SiS 900 PCI Fast Ethernet at 0xd400, IRQ 3, 00:d0:09:a9:35:64
[ 6.815552] pata_acpi 0000:00:0f.0: hardcoded PCI INT A -> IRQ 14
[ 6.839304] pata_ali 0000:00:0f.0: hardcoded PCI INT A -> IRQ 14
[ 6.845996] scsi0 : pata_ali
[ 6.846715] scsi1 : pata_ali
[ 6.846852] ata1: PATA max UDMA/66 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 6.846862] ata2: PATA max UDMA/66 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 7.018854] ata1.00: ATA-5: ST310212A, 3.02, max UDMA/66
[ 7.018872] ata1.00: 20005650 sectors, multi 32: LBA
[ 7.019278] ata1.01: ATA-5: QUANTUM FIREBALLlct20 20, APL.0900, max UDMA/100
[ 7.019287] ata1.01: 39876480 sectors, multi 8: LBA
[ 7.033548] ata1.00: configured for UDMA/66
[ 7.051339] ata1.01: configured for UDMA/66
[ 7.213448] ata2.00: ATAPI: CD-950E/TKU, A4C, max UDMA/33
[ 7.213483] ata2.00: WARNING: ATAPI DMA disabled for reliablity issues. It can be enabled
[ 7.213491] ata2.00: WARNING: via pata_ali.atapi_dma modparam or corresponding sysfs node.
[ 7.213509] ata2.00: simplex DMA is claimed by other device, disabling DMA
[ 7.221442] ata2.00: configured for PIO4
[ 7.221998] scsi 0:0:0:0: Direct-Access ATA ST310212A 3.02 PQ: 0 ANSI: 5
[ 7.222513] scsi 0:0:1:0: Direct-Access ATA QUANTUM FIREBALL APL. PQ: 0 ANSI: 5
[ 7.223158] scsi 1:0:0:0: CD-ROM E-IDE CD-950E/TKU A4C PQ: 0 ANSI: 5
[ 8.913375] usbcore: registered new interface driver libusual
[ 8.951530] Initializing USB Mass Storage driver...
[ 8.954487] scsi2 : SCSI emulation for USB Mass Storage devices
[ 8.954905] usbcore: registered new interface driver usb-storage
[ 8.954920] USB Mass Storage support registered.
[ 8.955406] usb-storage: device found at 2
[ 8.955413] usb-storage: waiting for device to settle before scanning
[ 9.012402] scsi 0:0:0:0: Attached scsi generic sg0 type 0
[ 9.012533] scsi 0:0:1:0: Attached scsi generic sg1 type 0
[ 9.012653] scsi 1:0:0:0: Attached scsi generic sg2 type 5
[ 9.160544] Driver 'sd' needs updating - please use bus_type methods
[ 9.161227] sd 0:0:0:0: [sda] 20005650 512-byte hardware sectors (10243 MB)
[ 9.161289] sd 0:0:0:0: [sda] Write Protect is off
[ 9.161297] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 9.161385] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.161638] sd 0:0:0:0: [sda] 20005650 512-byte hardware sectors (10243 MB)
[ 9.161684] sd 0:0:0:0: [sda] Write Protect is off
[ 9.161693] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 9.161774] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.161793] sda: sda1
[ 9.186302] sd 0:0:0:0: [sda] Attached SCSI disk
[ 9.186733] sd 0:0:1:0: [sdb] 39876480 512-byte hardware sectors (20417 MB)
[ 9.186794] sd 0:0:1:0: [sdb] Write Protect is off
[ 9.186803] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 9.186898] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.187105] sd 0:0:1:0: [sdb] 39876480 512-byte hardware sectors (20417 MB)
[ 9.187154] sd 0:0:1:0: [sdb] Write Protect is off
[ 9.187163] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 9.187251] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 9.187265] sdb:<4>Driver 'sr' needs updating - please use bus_type methods
[ 9.192980] sdb1 sdb2 < sdb5 >
[ 9.221400] sd 0:0:1:0: [sdb] Attached SCSI disk
[ 9.258843] sr0: scsi3-mmc drive: 4x/52x cd/rw xa/form2 cdda tray
[ 9.258867] Uniform CD-ROM driver Revision: 3.20
[ 9.259297] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 10.270470] PM: Starting manual resume from disk
[ 10.270496] PM: Resume from partition 8:17
[ 10.270501] PM: Checking hibernation image.
[ 10.271188] PM: Resume from disk failed.
[ 10.368730] EXT3-fs: INFO: recovery required on readonly filesystem.
[ 10.368750] EXT3-fs: write access will be enabled during recovery.
[ 11.130383] kjournald starting. Commit interval 5 seconds
[ 11.130477] EXT3-fs: sda1: orphan cleanup on readonly fs
[ 11.130505] ext3_orphan_cleanup: deleting unreferenced inode 554104
[ 11.130655] ext3_orphan_cleanup: deleting unreferenced inode 554102
[ 11.130679] ext3_orphan_cleanup: deleting unreferenced inode 554094
[ 11.130703] ext3_orphan_cleanup: deleting unreferenced inode 554093
[ 11.130728] ext3_orphan_cleanup: deleting unreferenced inode 416477
[ 11.130822] EXT3-fs: sda1: 5 orphan inodes deleted
[ 11.130829] EXT3-fs: recovery complete.
[ 11.256639] EXT3-fs: mounted filesystem with ordered data mode.
[ 13.956502] usb-storage: device scan complete
[ 13.963398] scsi 2:0:0:0: Direct-Access Seagate FreeAgent Go 100F PQ: 0 ANSI: 4
[ 15.398162] sd 2:0:0:0: [sdc] 156301488 512-byte hardware sectors (80026 MB)
[ 15.405137] sd 2:0:0:0: [sdc] Write Protect is off
[ 15.405149] sd 2:0:0:0: [sdc] Mode Sense: 1c 00 00 00
[ 15.405157] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[ 15.416174] sd 2:0:0:0: [sdc] 156301488 512-byte hardware sectors (80026 MB)
[ 15.423143] sd 2:0:0:0: [sdc] Write Protect is off
[ 15.423155] sd 2:0:0:0: [sdc] Mode Sense: 1c 00 00 00
[ 15.423164] sd 2:0:0:0: [sdc] Assuming drive cache: write through
[ 15.423186] sdc: sdc1 sdc2 sdc3
[ 15.433736] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 15.434429] sd 2:0:0:0: Attached scsi generic sg3 type 0
[ 21.665504] udevd version 124 started
[ 23.851607] Linux agpgart interface v0.103
[ 24.007277] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 24.044566] agpgart-ali 0000:00:00.0: ALi M1631 chipset
[ 24.113080] agpgart-ali 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
[ 24.128698] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 24.188426] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 25.242427] logips2pp: Detected unknown logitech mouse model 89
[ 25.743629] input: ImExPS/2 Logitech Explorer Mouse as /devices/platform/i8042/serio1/input/input3
[ 27.157046] acer_wmi: Unknown symbol wmi_evaluate_method
[ 27.158109] acer_wmi: Unknown symbol wmi_has_guid
[ 27.159660] acer_wmi: Unknown symbol wmi_query_block
[ 28.876021] PCI: setting IRQ 5 as level-triggered
[ 28.876037] C-Media PCI 0000:00:0c.0: found PCI INT A -> IRQ 5
[ 35.537152] parport_pc 00:09: reported by Plug and Play BIOS
[ 35.537257] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 35.634375] lp0: using parport0 (interrupt-driven).
[ 37.141506] Adding 497972k swap on /dev/sdb1. Priority:-1 extents:1 across:497972k
[ 137.393606] EXT3 FS on sda1, internal journal
[ 140.939284] kjournald starting. Commit interval 5 seconds
[ 140.939717] EXT3 FS on sdb5, internal journal
[ 140.939737] EXT3-fs: mounted filesystem with ordered data mode.
[ 141.497272] type=1505 audit(1226992798.311:2): operation="profile_load" name="/usr/share/gdm/guest-session/Xsession" name2="default" pid=4664
[ 142.229995] type=1505 audit(1226992799.043:3): operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" name2="default" pid=4669
[ 142.231944] type=1505 audit(1226992799.043:4): operation="profile_load" name="/usr/sbin/cupsd" name2="default" pid=4669
[ 142.486477] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 144.551158] acpi_cpufreq: Unknown symbol acpi_processor_notify_smm
[ 144.551560] acpi_cpufreq: Unknown symbol acpi_processor_unregister_performance
[ 144.553314] acpi_cpufreq: Unknown symbol acpi_processor_preregister_performance
[ 144.553956] acpi_cpufreq: Unknown symbol acpi_processor_register_performance
[ 146.107549] warning: `avahi-daemon' uses 32-bit capabilities (legacy support in use)
[ 146.216082] apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
[ 146.610407] ppdev: user-space parallel port driver
[ 151.098938] Bluetooth: Core ver 2.13
[ 151.108055] NET: Registered protocol family 31
[ 151.108076] Bluetooth: HCI device and connection manager initialized
[ 151.108090] Bluetooth: HCI socket layer initialized
[ 151.176168] Bluetooth: L2CAP ver 2.11
[ 151.176208] Bluetooth: L2CAP socket layer initialized
[ 151.250244] Bluetooth: RFCOMM socket layer initialized
[ 151.251427] Bluetooth: RFCOMM TTY layer initialized
[ 151.251453] Bluetooth: RFCOMM ver 1.10
[ 151.256485] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 151.256504] Bluetooth: BNEP filters: protocol multicast
[ 151.378545] Bridge firewalling registered
[ 151.380159] pan0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
[ 151.435596] Bluetooth: SCO (Voice Link) ver 0.6
[ 151.435618] Bluetooth: SCO socket layer initialized
[ 156.162970] NET: Registered protocol family 17
[ 157.675278] eth0: Media Link On 100mbps full-duplex
[ 273.998065] ppdev0: registered pardevice
[ 274.049588] ppdev0: unregistered pardevice
[ 275.613159] ppdev0: registered pardevice
[ 275.661106] ppdev0: unregistered pardevice
[ 275.820739] ppdev0: registered pardevice
[ 275.868741] ppdev0: unregistered pardevice
[ 302.743437] NET: Registered protocol family 10
[ 302.753443] lo: Disabled Privacy Extensions
[ 313.705057] eth0: no IPv6 routers present
