1 - 15 of 15 Posts
<img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> Not good news..<br />
<br />
This morning i decided to remove my stock HS , and install Thermalright SI-128 .. <br />
<br />
I think i made a huge mistake, when removing the stock thermalpaste , by rubbing it off i applied a dab of water to remove some of the thermalpaste ..<br />
<br />
When i installed the new HS there was no "post" , everything booted up but nothing showed up my screeen ! , i then removed HS and notcied i over applied the thermalpaste , and redid the same as before.. again it didnt "post" <br />
<br />
I'm scared.. <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /><br />
<br />
EDIT: I looked at the bottom of the heatsink and noticed a small strip of darker brown.. althought i believe that was there when i received the CPU
Discussion Starter #2
any ideas <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
Do you have anyway to check it with a different pc to see if it is functional?
Discussion Starter #4
no <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">
hmm... clean it up as good as you can and try to RMA it, saying it came like this <img alt="" class="inlineimg" src="/images/smilies/sneaky.gif" style="border:0px solid;" title="Sneaky">
Discussion Starter #6
So it's definately fried <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown">?
I doubt you fried it by reapplying thermal paste and a heatsink. Check all plugs make sure they are all in.
Sorry for the double post but also. If you removed the CPU to apply the thermal paste make sure the CPU is full back in its socket, otherwise that exact problem would happen <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Reactions: Mystikx
Do you have a fan with that ThermerRight cooler, or you using it passive? If passive, the lack of a CPU fan might result in failure to post.
Reactions: Mystikx
Discussion Starter #10
Thank you, give me some hope <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">!<br><br>
This reason i'm concerned is because this is my first time..<br>
OMG I JUST REALIZED I UNPLUGGED A 4 PIN PLUG BECAUSE IT WAS IN THE WAY IF MY HEATSINK ! YES I LOVE U
working now? <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
Reactions: Mystikx
<3 right back, called that one<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"><br><br>
I have had my compter not post so many times over the years... now I look back and smile
How is that SI128 working for you man?<br><br>
I'm thinkin about getting one + an FM121 for extreme air cooling on my pressy @ 4.2Ghz or more <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
<tr>
<div>
Originally Posted by <strong>Mystikx</strong>
</div>
<div style="font-style:italic">Thank you, give me some hope <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />!<br />
<br />
This reason i'm concerned is because this is my first time..<br />
OMG I JUST REALIZED I UNPLUGGED A 4 PIN PLUG BECAUSE IT WAS IN THE WAY IF MY HEATSINK ! YES I LOVE U</div>
</td>
</tr>
</table>
</div>I dont know how many times I have freaked out because i made a mistake like that.
1 - 15 of 15 Posts
