UK Best 2500k cooler
859 25
hi guys
im in the UK so what cooler for £40 max do you people recommend?
I want the D14 or Silver Arrow but they out of my price range.
I heard good things about CM Hyper 212 plus but will that do 4.8ghz on a 2500k if my chip is a good OCer?
1 - 20 of 26 Posts
Originally Posted by nekromantik;15189347
hi guys
The Hyper 212+ will do that, yes, and it will do it even better with slightly improved fans from the stock one (or push/pull with a second Blademaster).
You could also look at the Hyper 212 Evo, basically a slightly improved Hyper 212+.
Originally Posted by nekromantik;15194032
I heard the V6 is quite loud however.
Is this true?
I'd imagine so, to be honest. I haven't heard a lot about the Vx coolers recently but I do remember hearing that they were pretty loud.
Sent from my T-Mobile G1
Discussion Starter · #12 ·
thats them out then ha ha
so currently my options are Hyper 212 Evo or Ven X RT
Is this true?
The V6GT might be louder than other coolers, but by no means is it a loud cooler. Don't forget it has two fans in push-pull, compared to the 1 fan included with the Hyper 212+/EVO and the V8. Mine is quiet in my opinion, and I'm running a total of 7 fans including the V6GT and excluding the PSU fan.
Performance-wise it's great, and IMO defnitely worth the money.
When I said "pretty loud" I basically meant what you said.
Originally Posted by Elohim
http://www.overclockers.co.uk/showpr...57&subcat=1395
this is probably THE best 120mm Tower Cooler. I Would definately get this, because for 30£ this is a bargain.
you could also buy one or two higher rpm fans if you need them.
You forgot the Archon
Anyway, that Venomous-X is a nice deal.
@cloppy: i'm talking twoer coolers for 120mm fans, archon is designed for 140mm fans.
You're right
The Archon is much taller.
1 - 20 of 26 Posts
