Have a few sets of each of these case feet.
Relic 021's - PC Case Feet with Steel inserts. Anti-VIBRATION
Description pulled from elsewhere.
These are £5 delivered, for a set
Relic 022-LP's - PC Case Feet with Steel inserts. Low Profile
Again description from elsewhere
And these are £4 delivered, for a set
Relic 022's - PC Case Feet with Steel inserts. Higher Clearance
And these are £6 delivered, for a set
If you would like a set or have any questions drop me a pm.
Relic DP 021's - Rubber Case Feet with Steel Inserts.
Quality computer case feet with steel inserts for added strength and rigidity.
The feet, when in its upright position, rest on rubber. This provides anti-vibration properties and also protects the surface the case is placed on.
The screw thread diameter is 10 mm. Please check the diameter of your case feet holes first.
These are great to rise the case to allow more ventilation to lower fans, prevent vibration upon floor/surface and for a smart appearance to your case.
Includes
4 Relic DP021 Computer Feet
4 Black Rubber Washers
4 Black Countersunk Screws
Height of Feet = 16mm
Clearance from bottom of case to the floor/surface
Ready to fit
Includes
Ready to fit
Relic DP 022-LP's - Rubber Case Feet with Steel Inserts.
Quality computer case feet, out-cased in rubber and contain steel inserts for added strength and rigidity.
These low profile feet are 12mm in height and 23mm in width.
The screw thread diameter is 5mm (M5). Please check the diameter of your case feet holes first.
These are great to rise the case to allow more ventilation to lower fans and help provide a smart appearance to your case.
Includes
4 Relic DP022-LP Computer Feet
4 Steel Washers (4mm Height)
4 Dome Head Screws (M5)
Height of Feet = 12mm
Ready to fit
Includes
Ready to fit
Relic DP 022's - Rubber Case Feet with Steel Inserts.
These feet are 24mm in height and 23mm in width.
Includes
4 Relic DP022 Computer Feet
Height of Feet = 24mm
Ready to fit
Includes
Ready to fit
