OFFICIAL ULPS CONFIGURATION UTILITY WEBSITE: CLICK HERE
Most recent: v1.1.4 (8/11/2011)
All downloads located here
***If you are on Vista or 7 you may need to run the program as an administrator else you will get "Access is denied" errors.***
In versions 1.1.4 and above you will get a reminder to run the program as an administrator if it detects that you are not one.
THIS PROGRAM IS NOT A VIRUS! As of late it is getting detected as a false positive by a lot of antiviruses because it makes registry modifications. Add an exception to your antivirus software and it will work without problems.
If you are still insecure, copy+paste the DOS code beneath into a *.bat file and run it from there.
Changelog
v1.1.4: Enhanced administrator check feature compatibility.
v1.1.3 (unreleased): Implemented better handling of > nul pipeline, user interface improvements.
v1.1.2: Added administrator check feature.
v1.1.1 (unreleased): Added "current status" (ULPS enabled/disabled) feature.
v1.1.0: Added tons of new code. New feature: report current ULPS status.
v1.0.4: Minor code organizational changes.
v1.0.3: Modified user input to recognize blank inputs and respond with an error.
v1.0.2: Reorganization of the Instructions menu.
v1.0.1: Tons of bug fixes.
ULPS Configuration Utilty
A standalone, DOS-based utility with a user interface for both enabling ULPS and disabling ULPS. For those who are too lazy to find the registry key or don't want to mess around with the registry.
This utility automatically changes the value of the EnableUlps value in your registry to either enable or disable ULPS.
In addition, you can back up and restore your ULPS registry key as a portable .reg file.
*Does not require installation*
Automated enable/disable ULPS application:
Run it once and it will enable/disable. There is no user interface.
Download Enable ULPS
Download Disable ULPS
Downloads are also available in the attachments.
This program was written in DOS batch file code.
Click below to read the entire code.
If you'd prefer to run the program as a batch file (if you believe I stuck malware into the .exe) feel free to copy + paste the text below and put it in a .bat file.
Released under the GNU General Public License v3
Feel free to made any modifications to the source code and share it at your own will!
v1.1.2 (8/11/2011): ftp://ftp.achromaticcomputing.com/ulps/ULPS_Configuration_Utility_v1.1.2.exe
v1.1.0 (8/10/2011): ftp://ftp.achromaticcomputing.com/ulps/ULPS_Configuration_Utility_v1.1.0.exe
v1.0.5 (8/9/2011): ftp://ftp.achromaticcomputing.com/ulps/ULPS_Configuration_Utility_v1.0.5.exe
v1.0.4 (8/9/2011): ftp://ftp.achromaticcomputing.com/ulps/ULPS_Configuration_Utility_v1.0.4.exe
Changelog
: : ULPS Configuration Utility
: : Version: v1.1.4
: : Written by Kiwi
: : CHANGELOG
: : v1.1.4 Enhanced administrator check feature compatibility.
: : v1.1.3 Implemented better handling of > nul pipeline, user interface improvements.
: : v1.1.2 Added administrator check feature.
: : v1.1.1 Added "current status" (ULPS enabled/disabled) feature.
: : v1.1.0: Added tons of new code. New feature: report current ULPS status.
: : v1.0.4: Minor code organizational changes.
: : v1.0.3: Modified user input to recognize blank inputs and respond with an error.
: : v1.0.2: Reorganization of the Instructions menu.
: : v1.0.1: Tons of bug fixes.
@ECHO OFF
title ULPS Configuration Utility v1.1.4
set REGKEYNAME=EnableUlps
set BACKUPDIR=%HOMEDRIVE%%HOMEPATH%\Desktop
REM CHECK ADMIN
REM
mkdir "%PROGRAMFILES%\Tempdir" > nul
IF %ERRORLEVEL%==0 (goto :removedir) ELSE (goto :notadmin)
:removedir
rmdir "%PROGRAMFILES%\Tempdir" > nul
goto :start
REM FIND CURRENT STATUS
REM
:start
reg query HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000 /v %REGKEYNAME% > nul
if not ErrorLevel 1 (
goto :statuscontinue
) else (
goto :statuserror
:statuscontinue
FOR /F "tokens=2* delims= " %%A IN ('REG QUERY "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000" /v %REGKEYNAME%') DO SET VALUE=%%B
IF "%VALUE%"=="0x0" (goto :disabled)
IF "%VALUE%"=="0x1" (goto :enabled)
set "STATUS=Error: Your ULPS key is present but its value is not 0 nor 1. Correct this by enabling or disabling ULPS."
set "LONGSTATUS1=ULPS is present in your registry (normal)"
set "LONGSTATUS2=ULPS key value not 0 nor 1 (abnormal)"
goto :menustart
:enabled
set "STATUS=ULPS is enabled"
set "LONGSTATUS2=ULPS key value currently 0x1--enabled (normal)"
goto :menustart
:disabled
set "STATUS=ULPS is disabled"
set "LONGSTATUS2=ULPS key value currently 0x0--disabled (normal)"
goto :menustart
:statuserror
set "STATUS=Error: ULPS registry key not found!"
set "LONGSTATUS1=ULPS is NOT present in your registry (abnormal)"
set "LONGSTATUS2=Check Troubleshooting section in the Usage Instructions menu."
goto :menustart
:menustart
cls
ECHO ULPS CONFIGURATION UTILITY v1.1.4
ECHO
ECHO.
PING 1.1.1.1 -n 1 -w 700 >NUL
ECHO Current status = %STATUS%
ECHO.
ECHO Select an action.
ECHO [1] Enable ULPS
ECHO [2] Disable ULPS
ECHO [3] Backup ULPS Key
ECHO [4] Restore ULPS Key
ECHO [5] Usage Instructions
ECHO [6] About
ECHO [7] Exit
ECHO.
:return
set /p DIR=Enter a number:
if "%DIR%"=="" goto :midreturn
if %DIR% == 1 goto :1
if %DIR% == 2 goto :2
if %DIR% == 3 goto :3
if %DIR% == 4 goto :4
if %DIR% == 5 goto :5
if %DIR% == 6 goto :6
if %DIR% == 7 goto :7
:midreturn
ECHO Please enter a valid number
goto :return
REM ENABLE ULPS
REM
:1
cls
ECHO ENABLE ULPS
ECHO.
ECHO.
:enable
set /p ANSWER=Enabling ULPS will modify registry values. It is highly recommended that you back up your ULPS key first. Continue? (Y/N)
if "%ANSWER%"=="" goto :midenable
if /i {%ANSWER%}=={y} (goto :1_0000_check)
if /i {%ANSWER%}=={yes} (goto :1_0000_check)
if /i {%ANSWER%}=={n} (goto :mainmenu)
if /i {%ANSWER%}=={no} (goto :mainmenu)
:midenable
ECHO Please enter either Y or N
ECHO.
goto :enable
:1_0000_check
ECHO.
ECHO Checking registry keys in 0000...
goto :1_0000
) else (
goto :1_error
:1_0000
ECHO Deleting registry key in key 0000...
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000 /v %REGKEYNAME% /f > nul
ECHO Adding registry key in key 0000...
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000 /v %REGKEYNAME% /t REG_DWORD /d 1 > nul
goto :1_0001_check
:1_0001_check
ECHO Checking registry keys in 0001...
reg query HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0001 /v %REGKEYNAME% > nul
goto :1_0001
) else (
goto :1_completed
:1_0001
ECHO Deleting registry key in key 0001...
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0001 /v %REGKEYNAME% /f > nul
ECHO Adding registry key in key 0001...
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0001 /v %REGKEYNAME% /t REG_DWORD /d 1 > nul
goto :1_0002_check
:1_0002_check
ECHO Checking registry keys in 0002...
reg query HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0002 /v %REGKEYNAME% > nul
goto :1_0002
) else (
goto :1_completed
:1_0002
ECHO Deleting registry key in key 0002...
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0002 /v %REGKEYNAME% /f > nul
ECHO Adding registry key in key 0002...
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0002 /v %REGKEYNAME% /t REG_DWORD /d 1 > nul
goto :1_0003_check
:1_0003_check
ECHO Checking registry keys in 0003...
reg query HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0003 /v %REGKEYNAME% > nul
goto :1_0003
) else (
goto :1_completed
:1_0003
ECHO Deleting registry key in key 0003...
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0003 /v %REGKEYNAME% /f > nul
ECHO Adding registry key in key 0003...
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0003 /v %REGKEYNAME% /t REG_DWORD /d 1 > nul
goto :1_0004_check
:1_0004_check
ECHO Checking registry keys in 0004...
reg query HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0004 /v %REGKEYNAME% > nul
goto :1_0004
) else (
goto :1_completed
:1_0004
ECHO Deleting registry key in key 0004...
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0004 /v %REGKEYNAME% /f > nul
ECHO Adding registry key in key 0004...
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0004 /v %REGKEYNAME% /t REG_DWORD /d 1 > nul
goto :1_0005_check
:1_0005_check
ECHO Checking registry keys in 0005...
reg query HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0005 /v %REGKEYNAME% > nul
goto :1_0005
) else (
goto :1_completed
:1_0005
ECHO Deleting registry key in key 0005...
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0005 /v %REGKEYNAME% /f > nul
ECHO Adding registry key in key 0005...
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0005 /v %REGKEYNAME% /t REG_DWORD /d 1 > nul
goto :1_0006_check
:1_0006_check
ECHO Checking registry keys in 0006...
reg query HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0006 /v %REGKEYNAME% > nul
goto :1_0006
) else (
goto :1_completed
:1_0006
ECHO Deleting registry key in key 0006...
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0006 /v %REGKEYNAME% /f > nul
ECHO Adding registry key in key 0006...
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0006 /v %REGKEYNAME% /t REG_DWORD /d 1 > nul
goto :1_completed
:1_error
ECHO.
ECHO Error: ULPS registry key not found. Check "Troubleshooting" section in Usage Instructions menu.
goto :mainmenu
:1_completed
ECHO.
ECHO Completed.
ECHO.
:restartmenu2
set /p RESTART=A system restart is required in order for registry changes to take effect. Restart? (Y/N)
if "%RESTART%"=="" goto :midrestartmenu2
if /i {%RESTART%}=={y} (goto :restart)
if /i {%RESTART%}=={yes} (goto :restart)
if /i {%RESTART%}=={n} (goto :mainmenu)
if /i {%RESTART%}=={no} (goto :mainmenu)
:midrestartmenu2
ECHO.
goto :restartmenu2
REM DISABLE ULPS
REM
:2
cls
ECHO DISABLE ULPS
ECHO.
ECHO.
:disable
set /p ANSWER=Disabling ULPS will modify registry values. It is highly recommended that you back up your ULPS key first. Continue? (Y/N)
if "%ANSWER%"=="" goto :middisable
if /i {%ANSWER%}=={y} (goto :2_0000_check)
if /i {%ANSWER%}=={yes} (goto :2_0000_check)
:middisable
ECHO.
goto :disable
:2_0000_check
ECHO.
goto :2_0000
) else (
goto :2_error
:2_0000
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000 /v %REGKEYNAME% /t REG_DWORD /d 0 > nul
goto :2_0001_check
:2_0001_check
goto :2_0001
) else (
goto :2_completed
:2_0001
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0001 /v %REGKEYNAME% /t REG_DWORD /d 0 > nul
goto :2_0002_check
:2_0002_check
goto :2_0002
) else (
goto :2_completed
:2_0002
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0002 /v %REGKEYNAME% /t REG_DWORD /d 0 > nul
goto :2_0003_check
:2_0003_check
goto :2_0003
) else (
goto :2_completed
:2_0003
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0003 /v %REGKEYNAME% /t REG_DWORD /d 0 > nul
goto :2_0004_check
:2_0004_check
goto :2_0004
) else (
goto :2_completed
:2_0004
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0004 /v %REGKEYNAME% /t REG_DWORD /d 0 > nul
goto :2_0005_check
:2_0005_check
goto :2_0005
) else (
goto :2_completed
:2_0005
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0005 /v %REGKEYNAME% /t REG_DWORD /d 0 > nul
goto :2_0006_check
:2_0006_check
goto :2_0006
) else (
goto :2_completed
:2_0006
reg add HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0006 /v %REGKEYNAME% /t REG_DWORD /d 0 > nul
goto :2_completed
:2_error
ECHO.
goto :mainmenu
:2_completed
ECHO.
ECHO Completed.
ECHO.
:restartmenu
:midrestartmenu
ECHO.
goto :restartmenu
:restart
ECHO Restarting system...
echo C|call shutdown.exe -r -t 05 -c "A system restart has been called by ULPS Configuration Utility. A system restart is required for ULPS modifications to take effect. Your system will restart in 5 seconds."
ECHO Restart initiated.
ECHO Closing utilty...
PING 1.1.1.1 -n 1 -w 2000 >NUL
exit
REM EXPORT KEY
REM
:3
cls
ECHO BACKUP ULPS REGISTRY KEY
ECHO.
ECHO.
set /p LOCATION=Default backup directory is %BACKUPDIR%. Enter the directory you would like to store your backup in, or type "skip" to leave default:
if not "%LOCATION%"=="skip" set "BACKUPDIR=%LOCATION%"
if "%LOCATION%"=="skip" goto :3_check
ECHO Backup directory set to %BACKUPDIR%.
goto :3_check
:3_check
ECHO.
ECHO Initializing registry backup...
ECHO Checking registry keys...
goto :3_export
) else (
goto :3_error
:3_export
ECHO Exporting ULPS key...
reg export "HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000" "%BACKUPDIR%\ULPS Key Backup.reg" /y > nul
ECHO.
ECHO Completed.
ECHO Your ULPS key has been backed up to %BACKUPDIR%\ULPS Key Backup.reg
goto :mainmenu
:3_error
goto :mainmenu
REM RESTORE KEY
REM
:4
cls
ECHO RESTORE ULPS REGISTRY KEY
ECHO.
ECHO.
set /p LOCATION2=Enter the directory in which "ULPS Key Backup.reg" is located:
ECHO Directory of backup set to %LOCATION2%\ULPS Key Backup.reg.
ECHO.
:restorekey
set /p restorequestion=This will overwrite current CCC settings and will restore your backup. Continue? (Y/N)
if "%restorequestion%"=="" goto :midrestorequestion
if /i {%restorequestion%}=={y} (goto :4_check)
if /i {%restorequestion%}=={yes} (goto :4_check)
if /i {%restorequestion%}=={n} (goto :mainmenu)
if /i {%restorequestion%}=={no} (goto :mainmenu)
:midrestorequestion
ECHO.
goto :restorekey
:4_check
ECHO.
ECHO Initializing registry restore...
goto :4_restore
) else (
goto :4_error
:4_restore
ECHO Merging ULPS registry key...
regedit /s "%LOCATION2%\ULPS Key Backup.reg" > nul
ECHO.
ECHO Completed.
goto :mainmenu
:4_error
ECHO.
goto :mainmenu
REM HOW-TO
REM
:5
cls
ECHO USAGE INSTRUCTIONS
ECHO.
ECHO.
:maininstructions
ECHO Select a guide to read.
ECHO [1] Info: ULPS and Crossfire
ECHO [2] How to: Manually enable/disable ULPS
ECHO [3] How to: Using this utility
ECHO [4] Troubleshooting
ECHO [5] Return to main menu
ECHO.
:instructions
set /p GUIDE=Enter a number:
if "%GUIDE%"=="" goto :midinstructions
if %GUIDE% == 1 goto :5_1
if %GUIDE% == 2 goto :5_2
if %GUIDE% == 3 goto :5_3
if %GUIDE% == 4 goto :5_4
if %GUIDE% == 5 goto :5_5
:midinstructions
goto :instructions
:5_1
cls
ECHO ULPS and Crossfire
ECHO.
ECHO ULPS prevents you from using third party applications to overclock GPUs in Crossfire. By default, ULPS is enabled which only allows you to overclock using AMD Overdrive in the Catalyst Control Center.
ECHO.
goto :maininstructions
:5_2
cls
ECHO Enabling/disabling ULPS
ECHO.
ECHO ULPS can be enabled/disabled by modifying the registry key:
ECHO.
ECHO HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000
ECHO.
ECHO by changing the value EnableUlps to 0 to disable, and 1 to enable. Depending on the number of unique driver versions that were present on your system, there may be multiple keys in the last folder. For example you may have 0001 and 0002 in addition to 0000.
ECHO.
ECHO If the EnableUlps value is not present in the key, create a new 32-bit DWORD value named "EnableUlps" and set its value to either 0 or 1.
ECHO.
:5_3
cls
ECHO Using this utility
ECHO.
ECHO -Enabling ULPS will scan the above registry directory for all the keys present, and will change the value of EnableUlps in all the keys to 1.
ECHO -Disabling ULPS will scan the above registry directory for all the keys present, and will change the value of EnableUlps in all the keys to 0.
ECHO -The ULPS key backup function will export the entire registry directory into a portable .reg file. You can merge it manually.
ECHO -The ULPS key restore function merges the .reg file with the registry.
ECHO.
:5_4
cls
ECHO Troubleshooting
ECHO.
ECHO -Error: ULPS registry key not found.
ECHO This error indicates one of two things: 1) You do not have AMD graphics drivers installed on your system, or 2) the EnableUlps key is missing from your system (for whatever reason). Add the value manually by using the step in Enabling/disabling ULPS.
ECHO -Error: The system was unable to find the specified registry key or value.
ECHO This is normal. The program will try to find extra keys in which EnableUlps may exist, and if it is not present it will complete the operation.
ECHO -Error: Your ULPS key is present but its value is not 0 nor 1. Correct this by enabling or disabling ULPS.
ECHO Your ULPS key is supposed to return either 1 for enabled or 0 for disabled. In the rare event that it is neither of these values, use either disable or enable and it will correct the value from whatever it is to either 0 or 1.
ECHO -When restoring a ULPS backup key, my CCC settings have changed.
ECHO The backup utility backs up your entire CCC settings folder (in which EnableUlps is contained), which will change all of your settings to what it was when you backed it up.
ECHO -I can't save a ULPS key backup.
ECHO At the end of the directory you must EXCLUDE the slash. I.e. G: is acceptable but G:\ will cause problems.
ECHO.
ECHO Kiwi, I've found another problem that isn't listed here. How can I tell you about it?
ECHO Send me a PM on the place you got this program from.
ECHO.
:5_5
goto :start
REM ABOUT
REM
:6
cls
ECHO ABOUT ULPS CONFIGURATION UTILITY
ECHO A DOS-based ULPS registry key modifier.
ECHO.
ECHO.
ECHO Written by Kiwi
ECHO Version: v1.1.4
ECHO Last updated 8/11/2011
ECHO.
ECHO ULPS key backup directory: %BACKUPDIR%
ECHO ULPS key location: HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000
ECHO.
ECHO %LONGSTATUS1%
ECHO %LONGSTATUS2%
ECHO.
goto :mainmenu
REM EXIT
REM
:7
ECHO Exiting utility
PING 1.1.1.1 -n 1 -w 500 >NUL
exit
:mainmenu
ECHO.
ECHO Press any key to return to the main menu.
pause > nul
goto :start
exit
:notadmin
cls
ECHO You are not running this program as an administrator.
ECHO This utility makes registry modifications that will not complete successfully unless given elevated administrator priviledges.
ECHO Please re-run this utility as an administrator by right-clicking the utility and clicking on "Run as administrator"
ECHO.
PING 1.1.1.1 -n 1 -w 3000 >NUL
:midnotadmin
ECHO Press enter to exit the utility.
set /p EXIT=...Or if you want to run the utility anyways, type "continue" and press enter.
if "%EXIT%" == "" goto :7
if /i "%EXIT%" == "continue" goto :start
ECHO.
ECHO Command not recognized.
goto :midnotadmin
: : Version: v1.1.4
: : Written by Kiwi
: : CHANGELOG
@ECHO OFF
REM CHECK ADMIN
REM
:removedir
goto :start
REM
:start
) else (
goto :statuserror
:statuscontinue
goto :menustart
:enabled
goto :menustart
:disabled
goto :menustart
:statuserror
goto :menustart
:menustart
cls
ECHO
ECHO.
ECHO.
ECHO [6] About
ECHO [7] Exit
ECHO.
:return
:midreturn
goto :return
REM ENABLE ULPS
REM
:1
cls
ECHO ENABLE ULPS
ECHO.
ECHO.
:enable
:midenable
ECHO.
goto :enable
:1_0000_check
ECHO.
goto :1_0000
) else (
goto :1_error
:1_0000
goto :1_0001_check
:1_0001_check
goto :1_0001
) else (
goto :1_completed
:1_0001
goto :1_0002_check
:1_0002_check
goto :1_0002
) else (
goto :1_completed
:1_0002
goto :1_0003_check
:1_0003_check
goto :1_0003
) else (
goto :1_completed
:1_0003
goto :1_0004_check
:1_0004_check
goto :1_0004
) else (
goto :1_completed
:1_0004
goto :1_0005_check
:1_0005_check
goto :1_0005
) else (
goto :1_completed
:1_0005
goto :1_0006_check
:1_0006_check
goto :1_0006
) else (
goto :1_completed
:1_0006
goto :1_completed
:1_error
ECHO.
goto :mainmenu
:1_completed
ECHO.
ECHO Completed.
ECHO.
:restartmenu2
:midrestartmenu2
ECHO.
goto :restartmenu2
REM DISABLE ULPS
REM
:2
cls
ECHO DISABLE ULPS
ECHO.
ECHO.
:disable
:middisable
ECHO.
goto :disable
:2_0000_check
ECHO.
goto :2_0000
) else (
goto :2_error
:2_0000
goto :2_0001_check
:2_0001_check
goto :2_0001
) else (
goto :2_completed
:2_0001
goto :2_0002_check
:2_0002_check
goto :2_0002
) else (
goto :2_completed
:2_0002
goto :2_0003_check
:2_0003_check
goto :2_0003
) else (
goto :2_completed
:2_0003
goto :2_0004_check
:2_0004_check
goto :2_0004
) else (
goto :2_completed
:2_0004
goto :2_0005_check
:2_0005_check
goto :2_0005
) else (
goto :2_completed
:2_0005
goto :2_0006_check
:2_0006_check
goto :2_0006
) else (
goto :2_completed
:2_0006
goto :2_completed
:2_error
ECHO.
goto :mainmenu
:2_completed
ECHO.
ECHO Completed.
ECHO.
:restartmenu
:midrestartmenu
ECHO.
goto :restartmenu
:restart
exit
REM EXPORT KEY
REM
:3
cls
ECHO.
ECHO.
goto :3_check
:3_check
ECHO.
goto :3_export
) else (
goto :3_error
:3_export
ECHO.
ECHO Completed.
goto :mainmenu
:3_error
goto :mainmenu
REM RESTORE KEY
REM
:4
cls
ECHO.
ECHO.
ECHO.
:restorekey
:midrestorequestion
ECHO.
goto :restorekey
:4_check
ECHO.
goto :4_restore
) else (
goto :4_error
:4_restore
ECHO.
ECHO Completed.
goto :mainmenu
:4_error
ECHO.
goto :mainmenu
REM HOW-TO
REM
:5
cls
ECHO.
ECHO.
:maininstructions
ECHO.
:instructions
:midinstructions
goto :instructions
:5_1
cls
ECHO.
ECHO.
:5_2
cls
ECHO.
ECHO.
ECHO.
ECHO.
ECHO.
:5_3
cls
ECHO.
ECHO.
:5_4
cls
ECHO.
ECHO.
ECHO.
:5_5
goto :start
REM ABOUT
REM
:6
cls
ECHO.
ECHO.
ECHO.
ECHO.
ECHO %LONGSTATUS1%
ECHO %LONGSTATUS2%
ECHO.
goto :mainmenu
REM EXIT
REM
:7
exit
:mainmenu
ECHO.
pause > nul
goto :start
exit
:notadmin
cls
ECHO.
:midnotadmin
ECHO.
goto :midnotadmin
