1 - 20 of 31 Posts
I finished my first Case mod, and I am utterly addicted, heres some pics.
What are some other cool case mods I could do to my Antec 300? Are there any kinds of case mods that help with cooling?
Thanks!
-Falven
Very nice, i like the difference compared to the usual rectangle. You need to sort those wires out though, it spoils it
Thanks!
-Falven
To help with cooling you can remove the HDD bay and move HDD's up.
Other then that replacing the fans youve already got with better ones.
Flip your psu upside down so it intakes from underneath the case...
False floor to separate and hide the psu and accompanying wires
Thanks!
-Falven
You could paint the inside maybe cold cathodes sound activated as i just recieved mine today.
Sweet, very unique take on the side window mod. Like said above not like a normal rectangular mod. Kinda looks like a Silverstone Raven.
Clean work, good job. Other mods: paint the interior black and add some lights/cathodes as phillipjos suggested, and then turn the thing into a wind-tunnel with a handful of 38mm-thick high-RPM fans.
Discussion Starter #12
That was my first thought
But i ended getting 2X "S-Flex" for the front, and using my two "Slip Stream" in the back due to noise
I did get 2 blue cathodes, idk about painting it inside, good suggestion, but me+paint = fail, we'll see
Thanks everyone!
-Falven
Thanks everyone!
-Falven
Use plast-i-dip instead of paint. No prep other than a good wash, no drips, and acts as a sound dampener. Check out the log of Black Beauty in my sig for the results.
looks awesome
Discussion Starter #16
I was thinking about that, but the question of thermodynamics came into my mind
Thanks everyone!
-Falven
Data Recovery Engineer
Nice mod. I will post mine once it is done (I am almost done painting mine)
1 - 20 of 31 Posts
