i saw somewhere that diamond has 3X the heat conductivity as copper, so i was thinking, get maybe 1 or 2mm or factory grade diamond (used in saws and machines, should be about 10$)and put that between arctic silver and the cpu then maybe more arctic silver, and then either a peltier with water cooling and this OC ing kit
http://www.xoxide.com/ovcokit.html
im sure it would get to 10 Degrees or lower
