ultimate cooling experiment
2307 17
i saw somewhere that diamond has 3X the heat conductivity as copper, so i was thinking, get maybe 1 or 2mm or factory grade diamond (used in saws and machines, should be about 10$)and put that between arctic silver and the cpu then maybe more arctic silver, and then either a peltier with LN2 cooling
http://www.overcool.com/Exec/product...&item_id=29988 and this OC ing kit
http://www.xoxide.com/ovcokit.html
im sure it would get to 10 Degrees or lower
just a dream, that would be like 600$ minimum
1 - 18 of 18 Posts
Originally Posted by MangledWookie
Didnt Thrilla do something similar!?
OFF TOPIC: Where IS Thrilla. I was away for a while, and now he is never on...
He's.... let just say he's not allowed here anymore
ouch.....major bannage i am guessing...... but not my place to say
anywho, this sounds like it should actually work, but for it to work- like Ty Auchter said- you will have to be extremely carefull.
this is the type of project that has big enough risks to make it interesting but not enough to make it unattemptable, so it is the perfect project in my mind.
if i had the money i would attempt it.
So you want to put a layer of diamond between your CPU and a peltier? I assume you would stilll be putting a watercooling system in which would have a coppper base connected to the CPU. If that is the case, then the limiting thermal resistance would still come from the artic silver and the copper base. Adding a piece of diamond in won't help since Q=(TH-TC)/R and since the resistance for the copper/artic silver is larger than the diamonds, then having the diamond real doesnt do anything (in fact it would add more resistance). Now if you used a "paste" made out of pure diamonds (and good luck with that) and used that instead of the artic silver, then it would transfer heat better (though probably only slightly better). Or if you made the CPU block out of diamonds then that would be better.
Just use some liquid metal...
Edit: I've got the 437w TEC from Winstch Labs (no longer in business, to my knowledge) and it gets -8°C load temps. That's with regular thermal paste. I'm thinking of getting some liquid metal between the copper and peltier to help lower heat resistance from the peltier. I'll let you know my results once I get the liquid metal.
he is correct.... just plain physic laws...
if you want to drop temps, then focus on lowering ambient temperature.
e.g. i had a crazy idea of making a 1,5m tube with 2-3 fans in it that will hose cool air from my window (which is always a little bit open) into my case.
This means that i'll have an about 16-20 oC temperature drop [even more in the cold winter nights
] of the air that will be used to cool my system.
I am sure that this will translate to a very formidable drop of my components' temperature.
It is not the same to cool your system using 25oC air and using 5oC air.
Well, of course this mod worths the trouble, only in regions and during seasons, where the outside temperature is at least 10oC colder than room temperature.
e.g. here in Greece (meditereanean climate) and Sep-March and especially between afternoon-dawn we have some good low temps...
i do not have immediate plans on doing this and testing it, as i don't have my system Oced at max, so i don't really need this...
If this don't look good on you, then maybe try to cut a hole in a fridge, put your case in it, so as only the front panel to be reachable, use an appropriate material to insulate the area around your case, so as no air from outside can go into the fridge and you are done....
PP
well, you can do this, but it's really silly.... i mean... when the Pentium family was introduced in the market and when me and my buddy found out what kind of heat was made from the CPU (compared to old 486 dx2 66 systems we used back then) we started making fun of how future PC systems (that's todays systems) will be mid and full tower fridges, and not aluminium cases
Today this is a reality, as i just saw a post of some guy talking about puting his PC in the fridge!!! Next thing you know, we'll start commenting on what brand of fridge is best for putting your PC in....
PP
Forgive me, but THIS is silly... maybe you'll prefer to use my above scheme of making the 2-3 fan tube to cool your system with way cooler air from the outside... I know that this mod cannot be used in every way as it has certain requirements, but in some cases (and when carefuly and well manufactured) i expect it to give an atleast 10oC drop in temperature of all components.
Elder Tribesman
I hear that Silver is one of the most conductive metals for heat.
I'd consider doing something with that as a base before diamonds... Just sounds cheaper!
Too bad silver is so maleable or i'm sure we'd see some pure-silver waterblocks and heatsinks, etc..
come on guys, the thread is 3 years old.
ok everyone!
#1 diamond dust would destroy the pump and erode the water blocks and tubes down to nothing
#2 READ THE FREAKIN DATE OF WHEN THE THREAD WAS STARTED
if it is over 3 mounths old DON'T POST
mods should rely set it so threads automaticaly close after 6 mounths like most other forums do.
1 - 18 of 18 Posts
