Multiplier
All multiplier locations require 0-Ohm resistances
PLL0 -> R19+R20+R21
PLL1 -> R22+R23+R24
PLL2 -> R25+R26+R13
PLL3 -> R14+R15+R16
PLL4 -> R17+R18+R27
A PLL is set to 0 if one or more of the locations are jumped. A PLL is set to 1 if none of the PLL's locations are jumped.
Example: PLL 0 is set to 0 if R19, R20, or R21 is jumped or if any combination of R19, R20, and R21 are jumped. PLL 0 is set to 1 if 19, R20, and R21 are not jumped.
Bus
Warning: All bus speed modification information for PowerBooks is completely untested. Use these settings at your own risk. All BOM resistors are 10K-Ohm.
BOM0 -> R665
BOM1 -> R644
BOM2 -> R683
Voltage
All voltage locations require 0-Ohm resistances.
VID0 -> R337+R336
VID1 -> R326+R325
VID2 -> R330+R329
VID3 -> R305+R304
VID4 -> R301+R876
When only the resistor on the left of the chart is jumped, the pin is set to 0. When the only resistor on the right side of the chart is jumped, the pin is set to 1. Example: D4 is set to 0 if only R757 is jumped. D4 is set to 1 if only R126 is jumped.
