Originally Posted by DeathONator
Now that you've hit your CPU wall. I should tell you that your power supply (PSU) can also limit your overclock as well. If you CPU's voltage is fluctuating alot, your CPU will not be stable. Your vcore fluctuates because your power supply either dosn't have enough power to keep it at the desired level or is too poorly made to keep your voltages at the that level despite how much power it can output. That is why it is important for overclockers to buy good PSUs.
Deathonator,you sir are my hero,if i had a sister i would send her to you with a pizza and a six pack>i've spent hours,days,weeks,almost 2 months now wondering what kind of sick joke my pc was playin on me.It had ITT smartguardian which i never trusted,then i got MBM5,here are my voltages(my vcore goes from 1.66 up to 1.77 and back and forth,no games fro me,very bad performance,yada yada. +-------------------------------------------------------------------------+
|Total number of readouts: 1693 CPU Speed: 1869 MHz |
|Running from: 1/12/2006 7:43:21 PM until: 1/12/2006 8:40:08 PM |
|Sensor | Current | Low | High | Average |
|Case | 28° C | 26° C | 30° C | 27° C |
|CPU | 34° C | 31° C | 34° C | 33° C |
|Sensor 3 | 0° C | 0° C | 0° C | 0° C |
|Core 0 | 1.66 V | 1.66 V | 1.73 V | 1.66 V |
|Core 1 | 2.52 V | 2.49 V | 2.60 V | 2.49 V |
|+3.3 | 2.57 V | 2.50 V | 2.66 V | 2.64 V |
|+5.00 | 4.15 V | 4.15 V | 4.77 V | 4.32 V |
|+12.00 | 11.82 V | 11.57 V | 12.34 V | 11.71 V |
|-12.00 | 0.06 V | -0.10 V | 0.64 V | -0.08 V |
|-5.00 | -6.01 V | -6.36 V | -5.81 V | -5.86 V |
|Fan 1 | 2922 RPM | 2884 RPM | 2960 RPM | 2918 RPM |
|Fan 2 | 0 RPM | 0 RPM | 0 RPM | 0 RPM |
|Fan 3 | 0 RPM | 0 RPM | 0 RPM | 0 RPM |
+-----------------------------+----------+----------+----------+----------+ 5v and 3.3v are too low,figured that was a PS issue,but the vcore bouncing around had me.You have saved a lot of hair on my head,and i stand humbled,but grateful.
