1 - 20 of 23 Posts
I'll be getting an Asus P5B Deluxe and e6400 soon....Do you think this heatsink will fit in the case? Anyone have it? I wanted the black one but....I hate fingerprints.
<tr>
<div>
Originally Posted by <strong>born2killU</strong>
</div>
<div style="font-style:italic">yes it will fit</div>
</td>
</tr>
</table>
</div>Thanks!
just find the dimensions of the heatsink and the case, then work it out <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
that way you definately know <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
That case is a beast. Very roomy, so you will have no problem. My friend has it with a Freezer 64 installed, and there is more than plenty of room left.
<tr>
<div>
Originally Posted by <strong>MasterBillyQuizBoy</strong>
</div>
<div style="font-style:italic">I'll be getting an Asus P5B Deluxe and e6400 soon....Do you think this heatsink will fit in the case? Anyone have it? I wanted the black one but....I hate fingerprints.</div>
</td>
</tr>
</table>
</div> It should fit but as a previous poster pointed out just measure it to be sure....I have a blck one and something you should know about them is you cant shut the top door if you have anything in the bays that sticks out even a little bit...Like a flip switch or any thing, it has to fit almost flush with the front of the case to enable the door to close....I have been cutting out the grills on mine and a couple of inches on either side, now I'm making mesh box's tyhat stick out a few inches to let me use whaever bay devices that I want to..It's a pain in the neck...Other than that it's a decent case, I waxed mine and it really brought out the shine ....
Discussion Starter #7
<tr>
<div>
Originally Posted by <strong>ira-k</strong>
</div>
<div style="font-style:italic">It should fit but as a previous poster pointed out just measure it to be sure....I have a blck one and something you should know about them is you cant shut the top door if you have anything in the bays that sticks out even a little bit...Like a flip switch or any thing, it has to fit almost flush with the front of the case to enable the door to close....I have been cutting out the grills on mine and a couple of inches on either side, now I'm making mesh box's tyhat stick out a few inches to let me use whaever bay devices that I want to..It's a pain in the neck...Other than that it's a decent case, I waxed mine and it really brought out the shine ....</div>
</td>
</tr>
</table>
</div>You waxed it? <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" /> That's awesome. I wonder what it would take to get a mirror-finish on the silver version I've heard that the case is really just yellow plastic painted over...hmmm, I'll look into it.<br />
<br />
I don't plan on really putting any CD or DVD drives into it. I have an external LG that I plan on connecting via firewire.
<div>Originally Posted by <strong>MasterBillyQuizBoy</strong></div>
<div style="font-style:italic;">You waxed it? <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick Out Tongue"> That's awesome. I wonder what it would take to get a mirror-finish on the silver version I've heard that the case is really just yellow plastic painted over...hmmm, I'll look into it.<br><br>
I don't plan on really putting any CD or DVD drives into it. I have an external LG that I plan on connecting via firewire.</div>
</td>
</tr></table></div>
My case is aluminum yours should be to, other than the front grill thats plastic..Yeah I just used some plain old Turtle wax helped it a lot...They are really a pretty nice case, I wish I would of gone ahead and bought the CM Stacker though....
Filthy Casual
Ya I didn't know that Aluminus was so expensive, or I would have gotten one.
I have that case with a freezer 64... I had to remove the air tube (if you will) over the processor for the freezer to fit. You will have to figure out a way to get the grate to screw into the case.
Tigerdirect.ca actually has the silver ultra aluminus for $72 Canadian. Pretty good deal for a full tower aluminum case. I'f love to try standing on one!<br><br><br><a href="http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1215772&CatId=1510" target="_blank">http://www.tigerdirect.ca/applicatio...772&CatId=1510</a><br><a href="http://assets.overclock.net.s3.amazonaws.com/8/88/88a4ae52_vbattach33314.jpeg"><img alt="LL" src="http://cdn.overclock.net/8/88/525x525px-LL-88a4ae52_vbattach33314.jpeg" style="width:371px;height:340px;"></a>
<div>Originally Posted by <strong>Robilar</strong></div>
<div style="font-style:italic;">Tigerdirect.ca actually has the silver ultra aluminus for $72 Canadian. Pretty good deal for a full tower aluminum case. I'f love to try standing on one!<br><br><br><a href="http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1215772&CatId=1510" target="_blank">http://www.tigerdirect.ca/applicatio...772&CatId=1510</a></div>
</td>
</tr></table></div>
I've got a black one , all I can say is dont do it.....I think you might flatten it..
I've done it...
The pic cracked me up.
I forgot to mention...<br><br>
I have had REALLY BAD luck with TigerDirect rebates through OnRebate.com. On 5 or so tries, I have only gotten 2 rebates...<br><br>
TigerDirect refunded my rebate 2 other times, but said "too bad" the most recent time.
Funny you should mention, I bought an Ultra power supply (the infamous exploder!!) and the rebate from Tigerdirect never came either (This was a couple of years ago). Good point.
<div>Originally Posted by <strong>stevemc</strong></div>
<div style="font-style:italic;">I forgot to mention...<br><br>
TigerDirect refunded my rebate 2 other times, but said "too bad" the most recent time.</div>
</td>
</tr></table></div>
Yeah I dont like Tiger much either..Usally get my stuff at the Egg or Zip Zoom &Fly...
I hope my Ultra XConnect doesn't 'splode.....
</td>
</tr></table></div>
Try it and see what happens <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
I think that guy was hung with a rope when they took the pic.
<div>Originally Posted by <strong>3xtr3m3</strong></div>
<div style="font-style:italic;">Try it and see what happens <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
I think that guy was hung with a rope when they took the pic.</div>
</td>
</tr></table></div>
Either that or he was a cardboard cut-out....<img alt="" src="http://forums.cosplay.com/images/smilies/2/spiny.gif" style="border:0px solid;">
1 - 20 of 23 Posts
