I want to lower my fan speeds because right now the Zalman cooler is really loud and its really annoying. The GPU temp is at 32C while Idle and around 40C while gaming, so I dont mind the extra temp rises if i lower the RPM of the fan.
I've used RivaTuner to lower the duty cycles from 35% to 30%, restarted pc and it still sounds the same. The GPU temp is still the same so I know this has not worked
I also tryed the EVGA Precision to try and lower the fan speeds, however when I try to set the duty cycle to anything below 35% and apply, it just resets it back to 35%.
I also used nTune to try lower the speeds but it only gave me the option to increase the speed while the GPU is in 3D mode.
So any ideas to what else I can try?
P.S if and when u do reply, could u answer it as simple as possible? Im a pc n00b when it comes to understanding what means what
