Hi,
I have an AMD A6 3400M CPU. The laptop is an Acer Aspire 5560.
Some info about the laptop:
6GB of ram (not that it matters for OC)
AMD Radeon HD 6520G Graphics
K12 Chipset
Some info about the CPU:
Series AMD A-Series
Codename Llano
Clock Rate 1400 - 2300 MHz
Level 2 Cache 4096 KB
Number of Cores / Threads 4 / 4
It is normally clocked at 1400MHz and one core can boost up to 2.3GHz for a brief time.
I have tried to overclock with both AMD OverDrive and K10 stat without success...
After OCing to 2.3GHz, the performance seems to be the same, while AMD overDrive only allows to OC to 1.5GHz.
To be clearer: In CPU Z and K10 stat, it shows the cores at 2.3GHz so it appears as if I have OC but there is no change in performance.
I think that the laptop has an upper limit for the CPU so it wont allow OCing.
Any clues on how I can remove the limit?
Thanks for your help.
K12 Chipset
Series AMD A-Series
Codename Llano
