1 - 9 of 9 Posts
Hi,
i have an AMD X3 720 BE 0904 and a Gigabyte MA790XT-UD4P. When i unlock my fourth core everything seems fine... Windows runs stable but when i read the Core temperature with any tools its say -245 or 0... So my CPU fan runs as slow as possible. When i stress test my CPU (Prime95) the fan does not spin up and my cpu overheats.... When i reset my bios and go back to X3 the temperature read out is fine.
Any ideas how to fix this?
Thanks.
I wouldn't use the 4th Core. It's primarily the reason why AMD turn it off in the first place. It's known to cause issues.
Run Speedfan or Coretemp to view your temps.
i have the same issue, the way im doing it. is overclock it as an x3
and up voltages to as safe as u want and check temps
then when ur oc'ing the 940 just dont go over that voltage. Temps should be similar from x3 to x4.
u can read them in bios but my temps in bios are messed. 18c idle when its like 25c ambient
if u figure it out lmk plz,
1 - 9 of 9 Posts
