Try run as admin first, but I wouldn't bother overclocking with CCC as it limits how high you can go. I'd recommend Sapphire Trixx as you can still have CCC installed, but get around the the OC limits in CCC at the same time
Using 11.12, switched to beta again no difference. I think it is because I am not installing on the OS volume (my ssd). I will put it on it instead of the HDD and see what happen.
Uninstall all ATI drivers. Then use the latest ATIMan Uninstaller to get rid of everything in the registry. Reinstall. It should work after that. Had that issue a few times.
