On MSI Afterburne 2.2.0 Beta 2 there is on difference.Originally Posted by xsever;12985787
Make sure you are running the latest version which is 2.2.0 beta 2.
If that does not work, then your card probably does not support voltage control since the voltage regulator is not supported by MSI AB or etc..
In MSI Afterburne 2.2.0 Beta 2 there are two files MSIAfterburner.cfgOriginally Posted by mikepahl318;12986082
This is what you have to di in teh .cfg file
[ATIADLHAL]
UnofficialOverclockingEULA= I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
UnofficialOverclockingMode= 1
AccessibilityCheckingPeriod= 0
I am running 2.2.0 beta 2.Originally Posted by Vipr3;12986208
Download this and you will be able to do whatever you want. Unless your card does not support voltage changes.
http://downloads.guru3d.com/-MSI-Afterburner-2.2.0-Beta-2-download-2604.html
