1 - 3 of 3 Posts
i need to copy a file during setup, without using the $oem$ directories. or, does anyone know how to create a file from the command prompt, and saving it automatically. i.e.: have the guirunonce section say "start edit....." with the entries of the bat file underneath, and then a command at the end to close and save the edit. or any other suggestions.
Just have the runonce call a batch file.
Batch file would have all the actions..
Edit:
And depends on what you are trying to do.. are you creating a new file? Editing an existing file? This action is OK to happen on final boot? Is this an XLS, DOC, TXT, RTF?
If you just need to append text to a txt file...
echo "blah blah blah">>c:\\windows\est.txt
Will write new line after last line break that says blah blah blah.
1 - 3 of 3 Posts
