1 - 17 of 17 Posts
· Tired
My friend gave me his Twin Frozr II for a 6970 ( Quite generous ) and I am here to unbox it and show it to you
The Box
The front, sharing things like Memory size and type, MSI's 3 year warranty, and many Nvidia related certifications like PhysX.
The back of the box, with specific info like the features it is compatible/comes with (Things like DirectX11, 3D Vision, HDMI, and CUDA), Requirements (such as at least 200mb of storage space, a PCI-E motherboard, and a 6 and 8 pin compliant Power Supply) and more specifications (Like model, memory size/bus, and output types)
Open a flap at the top, and you see the card itself behind some transparent material, and some hardware specific features like MSI's Dual Heat-pipe design, it's Dual fans, it's copper base, and it's high density heat-sink.
Here we see the cards ability to last for about 12 years under constant load (don't know how they made that calculation
), their no explosion guarantee (good to know XD). Also we see cool things about MSI's trademark Overclock Utility MSI Afterburner, and even some comments from people like TechPowerUp! about the Twin Frozr II design itself.
Hardware and Accessories
Here is the actual card, in all of it's splendor. We see things that the box told us about like the large high-density heat-sink, the dual pipe design, and the dual fans.
A DVI to VGA adapter for legacy monitors.
A 6 pin to 8 pin power converter cable.
Drivers, MSI Live Update, and MSI Afterburner Installation disk.
A MHDMI to HDMI cable for those without MHDMI ports on their monitors.
In Depth on the card
A close up on the front of the card. Again we see the large heat-sink, dual fans, and dual pipe design.
Here we see the PCB board, the heat-sink and the big mess of pipes, keeping this thing cool.
The 8-pin and 6-pin power ports that supply power for the card.
A closeup at the I/O plate, and the 2 Dual Link DVI and MHDMI ports.
And that about wraps up the Unboxing! I MAY show you guys things like temps and the User Interface of the NVidia Control Panel later. See you!
· Fortnite Fanatic
Beautiful Card!
· Tired
Discussion Starter · #12 ·
Originally Posted by Citra;12999901
Introduce me to your friend.
Hehe well he is very fortunate to have a quite rich family (at least in this economy anyway) and he valued by 6970 over his GTX 580. He had 2 6970s already, and wanted a third quite bad.
Originally Posted by skarm;12999928
oh my god what is wrong with you
Again what?
EDIT AGAIN: If you guys think this is ******ed/wrong in any way, why bother looking at the thread? You aren't obligated to see this thread.....
· Premium Member
I considered that card when I bought my Asus Direct CU. The Asus was actually a bit cheaper at the time. It's only disadvantage (depending on your setup) is it's 3 slots while the MSI is only 2.
· Tired
Discussion Starter · #17 ·
Originally Posted by PcKiller
I like my GTX 580 too. But mine came with that Arctic Accelero Xtreme Plus Cooler already on it.
LUCKY
Yea I was considering the Asus Direct CU, but man is it bulky....
1 - 17 of 17 Posts
