1 - 2 of 2 Posts
Good morning.
There was a problem in Ubuntu 15.10 which I solved making a file system check with command:
sudo fsck /dev/sda1
After that, everything was working fine. The only new thing that I have made since file system check, is that I have used qBittorrent to download some torrent files. Since I've installed 15.10, I had no problems with qBittorrent client. The wrong thing in Opera (or whole system) must have been done by the specific file(s) that I tried to download. Maybe these files were too frail to let Opera be failed. It now shuts down unexpectedly, and with the specific Opera installation file I had made the set up, and I've been working a long time ago until a few days ago. With the specific set up (an before torrents - I guess - ) Opera did not such make shut down.
I uninstalled it 4 time with command
sudo apt-get --purge remove opera-developer
and
sudo apt-get --purge autoremove
and reinstalled it with
sudo gdebi opera-developer_37.0.2142.0_amd64.deb
I get no error message in installation. Everything is right installed. However, working in a new installation, after a couple of minutes, suddenly, again it shuts down.
I give you installation output if it helps you:
Fast and secure web browser
Opera is a fast, secure, and user-friendly web browser.
It includes web developer tools, news aggregation, and the ability
to compress data via Opera Turbo on congested networks.
Do you want to install the software package? [y/N]:y
Selecting previously unselected package opera-developer.
(Reading database ... 249500 files and directories currently installed.)
Preparing to unpack opera-developer_37.0.2142.0_amd64.deb ...
Unpacking opera-developer (37.0.2142.0) ...
Setting up opera-developer (37.0.2142.0) ...
update-alternatives: using /usr/bin/opera-developer to provide /usr/bin/x-www-browser (x-www-browser) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/man1/x-www-browser.1.gz because associated file /usr/share/man/man1/opera-developer.1.gz (of link group x-www-browser) doesn't exist
update-alternatives: using /usr/bin/opera-developer to provide /usr/bin/gnome-www-browser (gnome-www-browser) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/man1/gnome-www-browser.1.gz because associated file /usr/share/man/man1/opera-developer.1.gz (of link group gnome-www-browser) doesn't exist
Processing triggers for shared-mime-info (1.3-1) ...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu3) ...
Processing triggers for bamfdaemon (0.5.2~bzr0+15.10.20150627.1-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for mime-support (3.58ubuntu1) ...
I think that the problem must have been created from torrents. But, anyway, even if not from torrents, I would like a solution.
Thank you for your time!
1 - 2 of 2 Posts
