1 - 7 of 7 Posts
Hey all,
I am wondering if there is a video card that can handle the Unigine Heaven Benchmark at 120fps minimum at all times? Or maybe this just isn't possible at this time?
I understand there is a noticeable difference with gaming at 60hz compared to 120hz monitors, so I'm wondering if a GPU in SLI or Crossfire can keep up with that frame rate at all times and at max details for 1920x1080 resolution? The AA is not too important, if that gets turned off then I think I would still be fine with that.
PC Enthusiast
1080p in unigine heaven with 120 average fps?
GTX 580 TRI SLI
Minimum? dont think it can be done
GTX 580 TRI SLI
Minimum FPS. There are parts of the benchmark where it dips down to 30ish FPS, even with the 580 Tri SLI at max details (IIRC)...
Seems to be a pretty intense benchmark.
Discussion Starter #5
Originally Posted by HAVO
lmao idiot kid trolling..
why not 240FPS?!?! its higher and "better"
/Thread
Originally Posted by revlimiter
Hey all,
You'll need one of these:
1 - 7 of 7 Posts
