1 - 5 of 5 Posts
I ran Unigine Valley on ExtremeHD with a 3570k @ 4.6, ram at 2000 and both cards at stock and with the max OC
The 660ti I used is this one http://www.newegg.com/Product/Product.aspx?Item=N82E16814121656&Tpk=dc2o%20660ti
Stock is 1058/6008 Max OC was 1135/6998
The 680 used is http://www.newegg.com/Product/Product.aspx?Item=N82E16814162105
Stock is 1175/6008 Max OC was 1200/6750 and its a 4GB card
660ti Stock
680 Stock LL
660ti OC LL
680 OC LL
Looks like a solid 10fps higher at every mark. Not sure if the extra price tag of the 680 is worth it... maybe at least not at this resolution.
So probably for $100 cheaper I coulda got a 670 then.
Or for even less a 7950
I'm a folder otherwise I woulda went AMD
1 - 5 of 5 Posts
