1 - 16 of 16 Posts
its usually under frequency/voltage or something to that matter and if u dont kow alought about it or u cant even find it i recomend that u dont overclock read the fourms for a bit then attenpt it im not being mean but if u cant find it in the bios then u shouldnt be overclocking
first off whats the maker of ur motherboard it will be easier to help u there are hundreds of bios's out there it will help me help u
if u dont know then u shouldnt be ocing but i will try to help download a program called everest home edition it will tell u all the specs of ur computer
o and welcome to the fourms
d be on the front
if its a prebuilt comp (sounds like it cause of the "box" to it) then your pretty much outta luck and stuck with what you got. Thats why you cant find any of the options in he bios.
1 - 16 of 16 Posts
