1 - 3 of 3 Posts
I couldn't get this from the sticky...are palomino's (xp2000+) always unlocked or does it depend on the week#?
I change my mult from 7 to 24.5 with no difference in clock speed. What gives...does this mean my cpu is indeed locked? I've heard my A7V8x will unlock all multipliers on palominos...do I have misinformation?
Darn... not sure. Are the L1 and L3 bridges cut? I think it was the L1s on the Pali!
Its the L1 Bridges. Yes your CPU is locked but is pretty easy to unlock. Google "Unlocking Palomino Athlon XPs" and you are sure to find an article on it. It involves using non-conductive thermal past to fill the gaps the laser made then drawing new bridges with a silver conductive pen.
1 - 3 of 3 Posts
