What is it?
Well I unlocked my secondary rig which got this 720 BE on a Gigabyte ga-ma770-ud3 rev2.0 with ACC enabled (per core)
Anyhow I ran Prime95 for 1½ hour Torture Test and it had no errors etc and max temp reached was 48c (using a Scythe Mugen 2)
Vcore is at 1,35.
Multi at auto.
CNQ is Disabled.
Anyhow what isthe max safe temp for an unlocked 720BE?
What is the max safe Vcore for an unlocked 720BE?
What is the max safe overclock/multi for an unlocked 720BE?
I reached 3,6ghz on 1.45vcore (could probly go lower) as a TRI core with highest temp at 50c full load (prime) stock vcore was 1.3
Is there no way to find out core temps btw?
Vcore is at 1,35.
Multi at auto.
CNQ is Disabled.
