1 - 14 of 14 Posts
Hey everyone, I'm new to this site, I'm good at understanding computers so I hope I can fit in well here. BTW, I'm new to AMD as I have had Pentium 2 to XEON processors.
So I heard my Processor has 2 locked cores. I want to use them. As a safety precaution if it is possible to unlock the cores, then I will under clock it to 2.5 GHz and make my Fan Speed MAX. So if it is possible to unlock the cores, then how do I do it?
Thanks
Originally Posted by The Killer Computer View Post
I am not quite sure if it supports ACC or NCC, if anyone knows please reply.
Thanks
Go into the system bios and look for an option that says "ACC" or "Advanced Clock Calibration"
Edit: According to google this board does have the option.
Anyone?
Set it to "Auto" and reboot, and just hope that it works. Once it boots into windows open the task manager and see how many cores it shows. If it doesn't boot then the cores are most likely bad.
With AMD overdrive just lower the multiplier to underclock.
1 - 14 of 14 Posts
