1 - 4 of 4 Posts
well my 5200 was modded by adding a heatsink of a mac laptop which was esxpensive at the time
This heatsink is great ive gotten a 175 mhz oc out of it both mem and core
Today I took my K6-2 heatsink and put it on my 5200 (attached with a rubber band). Then I took my stock 60mm fan and rubber-banded it to the hs. *Apparently a 60mm fan's blades cover an entire 40mm heatsink
Originally Posted by marcin123b
how much you oc it?
Well it managed to get 316/483.. This card doesnt like to OC very well. But it can run CS:S at max at 1024x768 with 20-30 fps usually (some spots/maps it lags a bit). Try yours.
1 - 4 of 4 Posts
