This thread is meant to be a cumulative resource for general usage eyefinity users with questions on game compatibility. As a work in progress it is dynamic and in some cases may need revision. All personally tested games are tested with 3x1 Landscape @ 5760x1080.
Any game that allows the config file or a native configuration/Hex to be tweaked in order to be made compatible or the game supports eyefinity within the in-game options I consider as a "yes", as for placement of the HUD/stretching/scaling, I play most of my games with it off when possible to begin with as I find it distracting so HUD placement comes down to preference. Games that have no current fix that I've found are listed as "no", and games that require a third-party fix, or non-native executable I list as a "third-party fix". As I find more and more fixes they will be listed to keep this list comprehensive.
<!-- AME Google Spreadsheet -->
https://spreadsheets.google.com/pub?key=0ApsrCBRo_JgwdGIwMXAyR05Db1E2QTNNX203YTB0dVE&w=275&h=700
Google Spreadsheet
Google Spreadsheet
