1 - 16 of 16 Posts
Linked below is a database of modified BIOSes for X58 motherboards patched with the latest microcode (0x1F for Westmere, 0x1D for Bloomfield) against Meltdown and all variants of Spectre. Make sure the operating system is also updated to be fully protected from speculative execution side-channel vulnerabilities (CVE-2017-5715, CVE-2017-5753, CVE-2017-5754).
While most of Nehalem CPUs received a new microcode from Intel, there is an early stepping (C0) that hasn't and therefore still vulnerable at the moment. However, these very few CPUs will also benefit from increased security and stability due to more recent microcode. In addition, the ROMs feature TRIM support for SSDs in RAID0 and extended CPU compatibility table for all motherboards.
Source: TechPowerUp
Thank you.
Nice to know the bios is there incase I want to update. RIIIE here.
Discussion Starter #3 (Edited)
Computer Specifications
Intel Xeon W3680 @ 4.4 GHz
ASUS P6T (vanilla)
12GB G.Skill DDR3 10-12-12-31-1T @ 2266 MHz
Nvidia GeForce GTX 970 @ 1516 MHz / 7364 MHz
Windows 7 up-to-date
3DMark Fire Strike
Original ROM: 11177
Patched ROM: 11149
AIDA64
Memory Read
Original ROM: 24179 MB/s
Patched ROM: 24618 MB/s
Memory Write
Original ROM: 20646 MB/s
Patched ROM: 20648 MB/s
Memory Copy
Original ROM: 27227 MB/s
Patched ROM: 26809 MB/s
Memory Latency
Original ROM: 51.0 ns
Patched ROM: 51.0 ns
CPU Queen
Original ROM: 68989
Patched ROM: 68958
CPU PhotoWorxx
Original ROM: 14755 MPixel/s
Patched ROM: 14749 MPixel/s
CPU ZLib
Original ROM: 440.9 MB/s
Patched ROM: 438.4 MB/s
CPU AES
Original ROM: 14873 MB/s
Patched ROM: 14871 MB/s
CPU Hash
Original ROM: 3821 MB/s
Patched ROM: 3821 MB/s
FPU VP9
Original ROM: 6238
Patched ROM: 3688
FPU Julia
Original ROM: 21861
Patched ROM: 21843
FPU Mandel
Original ROM: 10531
Patched ROM: 10530
FPU SinJulia
Original ROM: 9074
Patched ROM: 9072
FP32 RayTrace
Original ROM: 3135 KRay/s
Patched ROM: 3135 KRay/s
FP64 RayTrace
Original ROM: 1734 KRay/s
Patched ROM: 1734 KRay/s
Packet Pusher
Thank you! Rep+
Oh wait...
ENTERPRISE!! FIX THE DAMNED REP SYSTEM ALREADY.
<3 you Enterprise!
Great post though, I have an X58 Sabertooth that's about to be my FPGA mining rig.
Thank you for all the hard work.
Extreme 5.97.4600 x5650 P6T-SE-ASUS-0908-MOD
3.60GHz (4.0Ghz turbo)
Memory Read 22,476
Memory Write 17,951
Memory Copy 24,853
Memory Latency 61.2ns
CPU Queen 56,774
CPU PhotoWorx 13,167
CPU ZLib 371.6
CPU AES 13,381
CPU Hash 3,303
FPU VP8 3,665
FPU Julia 17,993
FPU Mandel 8,663
FPU SinJulia 8,165
FP32 Ray-Trace 2,650
Just tried flashing the Gigabyte GA-X58A-UD3R (Revision 2.0) image via Q-Flash.
I'm getting an "invalid BIOS file" error. Won't let me flash. Should I re-download? Flash via a different means?
Now it should work. Please re-download.
Same story as before. I also swapped my keyboard with another one (PS/2) and turned off multi-threading (2 things I read can affect BIOS flashing for some strange reason). Anyway, got the same error messages as before, in DOS as well as Q-Flash. No clue what's wrong.
EDIT: worked with Regeneration to test differently compiled versions of the same BIOS. Got one that worked! UD3R updated with microcode.
Iconoclast
There is an FF3 version of this boards firmware that I've been using for seven years that never made it on to Gigabyte's public sites. Seems to work well...I'll see if I can find a link.
Just tried. Got the error message !! Bad BIOS Image !! and wouldn't flash.
Modded Gigabyte firmware of this era often need the engineer version of EFIFLASH to bypass incorrect checksums.
Discussion Starter #14
Added ROMs for even more vendors. So far, only Intel's mobos are missing from the list, their BIOS has too many checksum checks.
Discussion Starter #15
I've updated all ROMs today.
Nothing drastic... extended CPU support for the less known brands.
Updated microcode of 106A4 to a more recent one.
Now all X58 users can benefit from this release.
1 - 16 of 16 Posts
