unplug HD = lose raid 0?
414 6
i need to do some changes in my rig and i was wondering if i unplug all my wires even on the HD would i lose my raid 0 setup?
1 - 7 of 7 Posts
As long as you don't unplug while it's running and make sure the power is off it should be ok
Linux Lobbyist
You don't list your OS in your sig, but assuming you're not running GNU/Linux (which has RAID auto-detect), then you'll be fine as long as you plug the drives back into their original ports.
1 - 7 of 7 Posts
