Well, I select a bunch of files (file type doesn't seem to matter) from local hard disk (have several ones), copy/paste to usb3 device (be it sticks or external hdd) and usually while it's copying, it stops and closes the copyying.. window. This happens almost 90% of the time IF COPYING LARGE FILES (in the GB's range).
It usually happens half way through all the files.
The reverse also happens, copying from usb3 devices to hdd's.
ALL the devices and hard disks are working, and no error message is displayed.
I used to have this problem with my older PC too (also AMD system and USB3, but all hardware including motherboard, different).
Running Windows 7 64 bit will all updates.
thanks
thanks
